[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0rc1-15-g22268fe
git at osgeo.org
git at osgeo.org
Sat Dec 19 07:10:00 PST 2020
the project "PostGIS".
via 22268fe43d169b9ab27968d34d11961ba8049eca (commit)
from 67f8455f2afdce80032f01be6c3ef961bf7c5125 (commit)
revisions in full, below.
commit 22268fe43d169b9ab27968d34d11961ba8049eca
Author: Regina Obe <lr at pcorp.us>
Date: Sat Dec 19 10:09:45 2020 -0500
Some cleanup
diff --git a/NEWS b/NEWS
index 57b453c..9edb9f7 100644
--- a/NEWS
+++ b/NEWS
@@ -1,6 +1,9 @@
+PostGIS 3.2.0
+2021/xx/xx
PostGIS 3.1.0
-2020/12/xx
+2020/12/18
This version requires PostgreSQL 9.6 or higher and GEOS 3.6 or higher
Additional features are enabled if you are running GEOS 3.9.
@@ -11,10 +14,7 @@ Additional features are enabled if you are running GEOS 3.9.
met or explicitly disabled (--without-protobuf)
- #4258, Separated postgis_sfcgal from postgis
into its own lib file and extension (Regina Obe)
- - svn number is replaced by git hash in version output
- (Sandro Santilli, Raúl Marín)
- #4577, Drop support for PostgreSQL 9.5 (Raúl Marín)
- - #4579, Drop postgis_proc_set_search_path.pl (Raúl Marín)
- #4601, ST_TileEnvelope signature changed.
- #3057, ST_Force3D, ST_Force3DZ, ST_Force3DM and ST_Force4D signatures changed.
@@ -34,6 +34,7 @@ Additional features are enabled if you are running GEOS 3.9.
for overlay with exact tolerance (Sandro Santilli)
- #4624, ST_HexagonGrid and ST_SquareGrid, set returning functions to
generate tilings of the plane (Paul Ramsey)
+ - #4624, ST_Hexagon and ST_Square, shape generators (Paul Ramsey)
- #4804, (GEOS 3.9+) ST_ReducePrecision allows valid precision reduction
(Paul Ramsey)
- #4710, ST_ClusterKMeans now works with 3D geometries (Darafei Praliaskouski)
@@ -80,7 +81,6 @@ Additional features are enabled if you are running GEOS 3.9.
- #4677, Share gserialized objects between different cache types (Raúl Marín)
- #4601, Add ST_TileEnvelope margin argument (Yuri Astrakhan)
- #2972, Add quiet mode (-q) to pgsql2shp (Kristian Thy)
- - #4617, Add configure switch `--without-phony-revision` (Raúl Marín)
- #3057, Optional value params for Force3D*, Force4D functions (Kristian Thy)
- #4569, Allow unknown SRID geometry insertion into typmod SRID column (Paul Ramsey)
- #4149, ST_Simplify(geom, 0) is now O(N).
diff --git a/extensions/upgradeable_versions.mk b/extensions/upgradeable_versions.mk
index a74af15..3e6f067 100644
--- a/extensions/upgradeable_versions.mk
+++ b/extensions/upgradeable_versions.mk
@@ -59,5 +59,4 @@ UPGRADEABLE_VERSIONS = \
3.0.2 \
3.0.3 \
3.1.0 \
- 3.1.1 \
- 3.2.0dev
+ 3.1.1dev
Summary of changes:
NEWS | 10 +++++-----
extensions/upgradeable_versions.mk | 3 +--
2 files changed, 6 insertions(+), 7 deletions(-)
hooks/post-receive
