[postgis-tickets] [PostGIS] #4821: PostGIS 3.1 + Postgres 13 MVT crash
trac at osgeo.org
Sun Dec 20 12:17:25 PST 2020
Reporter: komzpa | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.1.0
Component: postgis | Version: 2.5.x
Keywords: |
[22:32] <Komzpa> Huston we have a problem
[22:32] <Komzpa>
https://gist.github.com/Komzpa/c5f1b970d45cd3aa11e4efc60c38295d
[22:34] <Komzpa> that might be because of mix of a debian postgres +
ubuntu postgis, let me revert both to ubuntu pgdg and recheck
[22:34] <strk> doesn't tell much, did you look at that line in postgresql
sourcecode ?
[22:37] <Komzpa>
https://github.com/postgres/postgres/blob/master/src/backend/executor/execExpr.c#L3214
[22:37] <Komzpa> Assert(as->d.agg_strict_input_check.jumpnull == -1);
[22:41] <Komzpa> the only aggregate in the query is ST_AsMVT(q, 'stats',
8192, 'geom')
[22:46] <RhodiumToad> that's ... not good
[22:47] <Komzpa> 22:46:02 [gis] > select ST_AsMVT(q, 'stats', 8192,
'geom') from (select 1 as id, 'POINT (0 0)' as geom) q;
[22:47] <Komzpa> ERROR: XX000: Unknown geometry type: 0 - Unknown
[22:47] <Komzpa> LOCATION: pg_error, lwgeom_pg.c:250
[22:47] <Komzpa> Time: 0,610 ms
[22:47] <Komzpa> 22:46:15 [gis] > select ST_AsMVT(q, 'stats', 8192,
'geom') from (select 1 as id, 'POLYGON(1 1, 3 3, 4 0, 1 1)' as geom) q;
[22:47] <Komzpa> ERROR: XX000: Unknown geometry type: 857748256 - Invalid
type
[22:47] <Komzpa> Time: 0,634 ms
[22:47] <Komzpa> does not look expected to me
[22:48] <Komzpa> no, going back and syncing versions does not help
[22:48] <RhodiumToad> I don't think that's relevant to your failed
assertion
[22:49] <Komzpa> the spot is the same
[22:49] <RhodiumToad> this looks like an oversight in the code?
[22:49] <Komzpa> I mean, it's a minimized example of my query that's
already misbehaving
[22:49] <Komzpa> but not yet to a crash
[22:49] <RhodiumToad> right, but if my guess is right, the crash depends
on amount of data
[22:50] <RhodiumToad> since it's related to aggregate
serialize/deserialize functions, which are used in parallel aggregation
[22:51] <RhodiumToad> you're testing on 13.1?
[22:53] <Komzpa> yes
[22:57] <Komzpa> RhodiumToad: does this sound like postgis or postgres
issue?
[22:57] <RhodiumToad> Komzpa: does that aggregate function have a
deserialize function that is not declared as strict?
[22:58] <RhodiumToad> my initial suspicion (not confirmed) is that it's a
postgres issue, but triggered by the presence of a non-strict deserialize
function (all the builtin deserialize functions are strict)
[22:58] <Komzpa> yes, since PostGIS 2.5.0
https://github.com/postgis/postgis/blob/8b13c3e2f8366d902dbf516ec17de09ae84361f4/postgis/postgis.sql.in#L4836
[22:59] <Komzpa> it was working okayish before postgis 3.1 upgrafe
[23:02] <Komzpa> 23:02:45 [gis] > alter function pgis_asmvt_deserialfn
strict;
[23:03] <Komzpa> RhodiumToad: as I understand that is expected to help?
[23:06] <RhodiumToad> well it might break the handling of nulls, depending
on how the other funcs for the aggregate are written
[23:07] <RhodiumToad> ... did it make any difference?
[23:08] <Komzpa> tonight there was crash on second 2, now job runs for 5
minutes finely already
[23:08] <Komzpa> so at least it helped the crash
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4821>
