[postgis-tickets] [SCM] PostGIS branch master updated. 95bff56e34567775329f98af94587a86c4a9a91d
git at osgeo.org
git at osgeo.org
Sat Feb 1 06:08:24 PST 2020
the project "PostGIS".
via 95bff56e34567775329f98af94587a86c4a9a91d (commit)
from 6da69e2d6a4e9b0009bfae49b0b126297c6df9e3 (commit)
revisions in full, below.
commit 95bff56e34567775329f98af94587a86c4a9a91d
Author: Raúl Marín <git at rmr.ninja>
Date: Sat Feb 1 13:56:47 2020 +0100
ST_HexagonGrid: Improve precision
Change the order of the operations so adjacent tiles have the exact
same coordinates
Closes #4627
Closes https://github.com/postgis/postgis/pull/544
diff --git a/postgis/lwgeom_generate_grid.c b/postgis/lwgeom_generate_grid.c
old mode 100644
new mode 100755
index bf84208..607f01b
--- a/postgis/lwgeom_generate_grid.c
+++ b/postgis/lwgeom_generate_grid.c
@@ -68,24 +68,20 @@ GeometryGridState;
/* Build origin hexagon centered around origin point */
static const double hex_x[] = {-1.0, -0.5, 0.5, 1.0, 0.5, -0.5, -1.0};
-static const double hex_y[] = { 0.0, -1*H, -1*H, 0.0, H, H, 0.0};
+static const double hex_y[] = {0.0, -0.5, -0.5, 0.0, 0.5, 0.5, 0.0};
static LWGEOM *
hexagon(double origin_x, double origin_y, double size, int cell_i, int cell_j, int32_t srid)
- double height = size * 2 * H;
- POINT4D pt;
POINTARRAY **ppa = lwalloc(sizeof(POINTARRAY*));
POINTARRAY *pa = ptarray_construct(0, 0, 7);
- uint32_t i;
- double offset_x = origin_x + (1.5 * size * cell_i);
- double offset_y = origin_y + (height * cell_j) + (0.5 * height * (abs(cell_i) % 2));
- for (i = 0; i < 7; ++i)
+ for (uint32_t i = 0; i < 7; ++i)
- pt.x = size * hex_x[i] + offset_x;
- pt.y = size * hex_y[i] + offset_y;
+ double height = size * 2 * H;
+ POINT4D pt;
+ pt.x = origin_x + size * (1.5 * cell_i + hex_x[i]);
+ pt.y = origin_y + height * (cell_j + 0.5 * (abs(cell_i) % 2) + hex_y[i]);
ptarray_set_point4d(pa, i, &pt);
diff --git a/regress/core/regress.sql b/regress/core/regress.sql
index 421af25..5503d05 100644
--- a/regress/core/regress.sql
+++ b/regress/core/regress.sql
@@ -307,6 +307,23 @@ select '313', Count(*) FROM ST_SquareGrid(100000, ST_TileEnvelope(4, 7, 7)) hex,
select '314', Count(*) FROM ST_SquareGrid(100000, ST_TileEnvelope(4, 2, 2));
select '315', Count(*) FROM ST_SquareGrid(100000, ST_TileEnvelope(4, 2, 2)) hex, ST_TileEnvelope(4, 2, 2) tile WHERE NOT ST_Intersects(hex.geom, tile);
+WITH geoms AS
+ SELECT * FROM (SELECT (ST_HexagonGrid(5, '01030000000100000005000000fdffffffff7f66c0fcffffffff7f56c0fdffffffff7f66c07cc0e71a95e8544000000000008066407cc0e71a95e854400000000000806640fcffffffff7f56c0fdffffffff7f66c0fcffffffff7f56c0')).*) sq WHERE i = 5 AND j IN (0, 1)
+j0 AS
+ SELECT * FROM geoms WHERE i = 5 AND j = 0
+j1 AS
+ SELECT * FROM geoms WHERE i = 5 AND j = 1
+SELECT '316',
+ ST_Intersects(j0.geom, j1.geom),
+ ST_AsText(ST_Intersection(j0.geom, j1.geom))
+FROM j0,j1;
-- Drop test table
DROP table test;
diff --git a/regress/core/regress_expected b/regress/core/regress_expected
index a06f5a3..aed3e61 100644
--- a/regress/core/regress_expected
+++ b/regress/core/regress_expected
@@ -230,3 +230,4 @@ ERROR: ST_TileEnvelope: Margin must not be less than -50%, margin=-0.510000
313|0
314|676
315|0
+316|t|LINESTRING(40 8.66025403784439,35 8.66025403784439)
Summary of changes:
postgis/lwgeom_generate_grid.c | 16 ++++++----------
regress/core/regress.sql | 17 +++++++++++++++++
regress/core/regress_expected | 1 +
3 files changed, 24 insertions(+), 10 deletions(-)
mode change 100644 => 100755 postgis/lwgeom_generate_grid.c
hooks/post-receive
