[postgis-tickets] [SCM] PostGIS branch master updated. 158e9e0c721ce50693e8cf7a95f276d769890fec
git at osgeo.org
git at osgeo.org
Sat Feb 1 11:34:50 PST 2020
the project "PostGIS".
via 158e9e0c721ce50693e8cf7a95f276d769890fec (commit)
from 95bff56e34567775329f98af94587a86c4a9a91d (commit)
revisions in full, below.
commit 158e9e0c721ce50693e8cf7a95f276d769890fec
Author: Regina Obe <lr at pcorp.us>
Date: Sat Feb 1 14:34:43 2020 -0500
Change install requirements to agree with README.postgis which seems more accurate
diff --git a/doc/installation.xml b/doc/installation.xml
index 961d678..95ec056 100644
--- a/doc/installation.xml
+++ b/doc/installation.xml
@@ -166,7 +166,7 @@ tar -xvzf postgis-&last_release_version;.tar.gz</programlisting>
<listitem>
<para>
- Proj4 reprojection library, version 4.6.0 or greater. Proj4 4.9 or above is needed to take advantage of improved geodetic.
+ Proj4 reprojection library. Proj4 4.9 or above is required.
The Proj4 library is used to provide coordinate reprojection support within
PostGIS. Proj4 is available for download from
<ulink url="http://trac.osgeo.org/proj/">
@@ -178,7 +178,7 @@ tar -xvzf postgis-&last_release_version;.tar.gz</programlisting>
<listitem>
<para>
- GEOS geometry library, version 3.6 or greater, but GEOS 3.7+ is recommended to take full advantage of all the new functions and features. GEOS is available for download from
+ GEOS geometry library, version 3.6 or greater, but GEOS 3.8+ is recommended to take full advantage of all the new functions and features. GEOS is available for download from
<ulink url="http://trac.osgeo.org/geos/">
</ulink>.
@@ -201,9 +201,7 @@ tar -xvzf postgis-&last_release_version;.tar.gz</programlisting>
<listitem>
<para>
- GDAL, version 1.8 or higher (1.9 or higher is strongly
- recommended since some things will not work well or behavior
- differently with lower versions). This is required for raster
+ GDAL, version 2+ is required 3+ is preferred. This is required for raster
support.
<ulink url="http://trac.osgeo.org/gdal/wiki/DownloadSource">http://trac.osgeo.org/gdal/wiki/DownloadSource</ulink>.
</para>
Summary of changes:
doc/installation.xml | 8 +++-----
1 file changed, 3 insertions(+), 5 deletions(-)
hooks/post-receive
