[postgis-tickets] [SCM] PostGIS branch master updated. 44f0e0bf9beb1d865b7a27e4275162b08104d909
Sat Feb 1 12:17:50 PST 2020
the project "PostGIS".
       via  44f0e0bf9beb1d865b7a27e4275162b08104d909 (commit)
      from  1f3cdb2fbec1681b424c94aaa78cd0aa604dde44 (commit)
revisions in full, below.
commit 44f0e0bf9beb1d865b7a27e4275162b08104d909
Author: Regina Obe <lr at pcorp.us>
Date:   Sat Feb 1 15:17:45 2020 -0500
    Update release notes in prep for 3.1.0alpha1 release
diff --git a/NEWS b/NEWS
index 8d1a472..5e546b8 100644
--- a/NEWS
+++ b/NEWS
@@ -1,11 +1,9 @@
-PostGIS 3.1.0
-2020/XX/XX
-* Deprecated signatures *
-  - Function postgis_svn_version() replaced by postgis_lib_revision()
-    (Sandro Santilli)
+PostGIS 3.1.0alpha1
+2020/02/01
 * Breaking changes *
+  - svn number replaced by git hash in version output
+    (Sandro Santilli, Raúl Marín)
   - #4577, Drop support for PostgreSQL 9.5 (Raúl Marín)
   - #4579, Drop postgis_proc_set_search_path.pl (Raúl Marín)
   - #4601, ST_TileEnvelope signature changed.
@@ -47,6 +45,10 @@ PostGIS 3.1.0
   - #4608, PG12: Fix several bugs in the index support function (Raúl Marín)
   - #4621, Prevent stack overflow when parsing WKB (Raúl Marín)
+* Deprecated signatures *
+  - Function postgis_svn_version() replaced by postgis_lib_revision()
+    (Sandro Santilli)
 PostGIS 3.0.0
 2019/10/20
diff --git a/README.postgis b/README.postgis
index 5c15110..65c449d 100644
--- a/README.postgis
+++ b/README.postgis
@@ -1,8 +1,8 @@
 PostGIS - Geographic Information Systems Extensions to PostgreSQL
-:Version: 3.1.0dev
-:Date: 2020-01-02
+:Version: 3.1.0alpha1
+:Date: 2020-02-01
 :Website: https://postgis.net
 This distribution contains a module which implements GIS simple features, ties
diff --git a/doc/release_notes.xml b/doc/release_notes.xml
index 257f1a2..6cc270a 100644
--- a/doc/release_notes.xml
+++ b/doc/release_notes.xml
@@ -4,6 +4,48 @@
     <subtitle>Release Notes</subtitle>
     <sect1>
+        <title>Release 3.1.0alpha1</title>
+        <para>Release date: 2020/02/01</para>
+        <para>This version requires PostgreSQL 9.5+-13 and GEOS >= 3.6+
+              Additional features and enhancements enabled if you are running Proj6+, PostgreSQL 12+, and GEOS 3.8.0</para>
+        <simplesect>
+          <title>Breaking Changes</title>
+            <para>svn number replaced by git hash in version output
+                  (Sandro Santilli, Raúl Marín)</para>
+            <para>4577, Drop support for PostgreSQL 9.5 (Raúl Marín)</para>
+            <para>4579, Drop postgis_proc_set_search_path.pl (Raúl Marín)</para>
+            <para>4601, ST_TileEnvelope signature changed.</para>
+            <para>3057, ST_Force3D, ST_Force3DZ, ST_Force3DM and ST_Force4D signatures changed.</para>
+        </simplesect>
+        <simplesect>
+          <title>New features</title>
+          <para>4601, Add ST_TileEnvelope margin argument (Yuri Astrakhan)</para>
+          <para>2972, Add quiet mode (-q) to pgsql2shp (Kristian Thy)</para>
+          <para>4617, Add configure switch `--without-phony-revision` (Raúl Marín)</para>
+          <para>3057, Optional value params for Force3D*, Force4D functions (Kristian Thy)</para>
+          <para>4624, ST_HexagonGrid and ST_SquareGrid, set returning functions to
+              generate tilings of the plane (Paul Ramsey)</para>
+        </simplesect>
+        <simplesect>
+          <title>Enhancements</title>
+            <para>4539, Unify libm includes (Raúl Marín)</para>
+            <para>4569, Allow unknown SRID geometry insertion into typmod SRID column (Paul Ramsey)</para>
+            <para>4149, ST_Simplify(geom, 0) is now O(N).
+                      ST_Affine (ST_Translate, ST_TransScale, ST_Rotate) optimized.
+                      ST_SnapToGrid optimized. (Darafei Praliaskouski)</para>
+            <para>4574, Link Time Optimizations enabled (Darafei Praliaskouski)</para>
+            <para>4578, Add parallellism and cost properties to brin functions (Raúl Marín)</para>
+            <para>4473, Silence yacc warnings (Raúl Marín)</para>
+            <para>4589, Disable C asserts when building without "--enable-debug" (Raúl Marín)</para>
+            <para>4543, Introduce ryu to print doubles (Raúl Marín)</para>
+            <para>4626, Support pkg-config for libxml2 (Bas Couwenberg)</para>
+            <para>4615, Speed up geojson output (Raúl Marín)</para>
+        </simplesect>
+    </sect1>
+    <sect1>
         <title>Release 3.0.0</title>
         <para>Release date: 2019/10/20</para>
         <para>This version requires PostgreSQL 9.5+-12 and GEOS >= 3.6+
Summary of changes:
 NEWS                  | 14 ++++++++------
 README.postgis        |  4 ++--
 doc/release_notes.xml | 42 ++++++++++++++++++++++++++++++++++++++++++
 3 files changed, 52 insertions(+), 8 deletions(-)
hooks/post-receive
