[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0alpha1-1-g8bcbe2f
git at osgeo.org
git at osgeo.org
Sat Feb 1 16:17:14 PST 2020
the project "PostGIS".
via 8bcbe2f44ae09d38ec641d69c79fe4e3bcb16ecc (commit)
from f7a36482863b881ebccbbbd0810c14936acab598 (commit)
revisions in full, below.
commit 8bcbe2f44ae09d38ec641d69c79fe4e3bcb16ecc
Author: Regina Obe <lr at pcorp.us>
Date: Sat Feb 1 19:17:09 2020 -0500
Flip back to 3.1.0dev and oops fix that 9.6+ is supported, not 9.5
diff --git a/HOWTO_RELEASE b/HOWTO_RELEASE
index abaca2e..abdb325 100644
--- a/HOWTO_RELEASE
+++ b/HOWTO_RELEASE
@@ -86,7 +86,7 @@ Release procedure
- Tag branch: (replace x.x and x.x.x with minor and micro version e.g 2.3, 2.3.1
$ rev=x.x.x
- $ git tag -am "Tagged release $rev"; git push osgeo --tags
+ $ git tag -a $rev -m "Tagged release $rev"; git push osgeo --tags
- Run: sh make_dist.sh $rev (note, debbie should have already done this,
and the file will be waiting in postgis.net/stuff. You might need to wait a few minutes to see it.)
If impatient check status of job - https://debbie.postgis.net/job/PostGIS_Make_Dist/
diff --git a/README.postgis b/README.postgis
index 65c449d..8ebb0cd 100644
--- a/README.postgis
+++ b/README.postgis
@@ -33,7 +33,7 @@ Directory structure::
REQUIREMENTS
-PostGIS is compatible with PostgreSQL 9.5 and above.
+PostGIS is compatible with PostgreSQL 9.6 and above.
You *must* have the full PostgreSQL - including server headers - installed for
this to work.
diff --git a/Version.config b/Version.config
index 854436e..e618043 100644
--- a/Version.config
+++ b/Version.config
@@ -5,7 +5,7 @@
POSTGIS_MAJOR_VERSION=3
POSTGIS_MINOR_VERSION=1
-POSTGIS_MICRO_VERSION=0alpha1
+POSTGIS_MICRO_VERSION=0dev
# Liblwgeom interface versioning, reset to 0:0:0 (cur:age:rev)
# when changing POSTGIS_MINOR_VERSION
diff --git a/doc/postgis.xml b/doc/postgis.xml
index 273e024..031ede1 100644
--- a/doc/postgis.xml
+++ b/doc/postgis.xml
@@ -13,7 +13,7 @@
<!-- Change these values to update the version numbers referenced within the documentation -->
<!ENTITY last_proj_release_version "5.1.0">
<!ENTITY last_geos_release_version "3.7.0">
-<!ENTITY min_postgres_version "9.5">
+<!ENTITY min_postgres_version "9.6">
<!ENTITY introduction SYSTEM "introduction.xml">
<!ENTITY installation SYSTEM "installation.xml">
diff --git a/doc/release_notes.xml b/doc/release_notes.xml
index 6cc270a..3bf9c17 100644
--- a/doc/release_notes.xml
+++ b/doc/release_notes.xml
@@ -6,7 +6,7 @@
<sect1>
<title>Release 3.1.0alpha1</title>
<para>Release date: 2020/02/01</para>
- <para>This version requires PostgreSQL 9.5+-13 and GEOS >= 3.6+
+ <para>This version requires PostgreSQL 9.6+-13 and GEOS >= 3.6+
Additional features and enhancements enabled if you are running Proj6+, PostgreSQL 12+, and GEOS 3.8.0</para>
<simplesect>
<title>Breaking Changes</title>
diff --git a/extensions/upgradeable_versions.mk b/extensions/upgradeable_versions.mk
index 9bacc9e..7ae796d 100644
--- a/extensions/upgradeable_versions.mk
+++ b/extensions/upgradeable_versions.mk
@@ -62,4 +62,4 @@ UPGRADEABLE_VERSIONS = \
3.0.0rc2 \
3.0.0 \
3.0.1dev \
- 3.1.0dev
+ 3.1.0alpha1
Summary of changes:
HOWTO_RELEASE | 2 +-
README.postgis | 2 +-
Version.config | 2 +-
doc/postgis.xml | 2 +-
doc/release_notes.xml | 2 +-
extensions/upgradeable_versions.mk | 2 +-
6 files changed, 6 insertions(+), 6 deletions(-)
hooks/post-receive
