[postgis-tickets] [PostGIS] #4638: bessie failing on GDAL segmentation fault
PostGIS trac at osgeo.org
Sat Feb 8 12:57:43 PST 2020
 Reporter:  robe                   |      Owner:  robe
     Type:  defect                 |     Status:  assigned
 Priority:  medium                 |  Milestone:  PostGIS 3.0.1
Component:  build/upgrade/install  |    Version:  3.0.x
 Keywords:                         |
 15:08:13 passed
 15:08:13   Test: test_gdal_to_raster ...passed
 15:08:13   Test: test_gdal_warp ...passed
 15:08:13 Suite: raster_geometry
 15:08:13   Test: test_raster_envelope ...passed
 15:08:13   Test: test_raster_envelope_geom ...gmake[4]: *** [Makefile:78:
 check] Segmentation fault (core dumped)
 15:08:14 gmake[4]: Leaving directory
 '/usr/home/jenkins/workspace/PostGIS_Worker_Run/label/bessie/0c190406e5edf3050c2883cc378e628fbdf26d3e/raster/test/cunit'
 15:08:14 gmake[3]: *** [Makefile:19: check-unit] Error 2
 15:08:14 gmake[3]: Leaving directory
 '/usr/home/jenkins/workspace/PostGIS_Worker_Run/label/bessie/0c190406e5edf3050c2883cc378e628fbdf26d3e/raster/test'
 15:08:14 gmake[2]: *** [Makefile:66: check-unit] Error 2
 15:08:14 gmake[2]: Leaving directory
 '/usr/home/jenkins/workspace/PostGIS_Worker_Run/label/bessie/0c190406e5edf3050c2883cc378e628fbdf26d3e/raster'
 15:08:14 gmake[1]: *** [GNUmakefile:20: check-unit] Error 1
 15:08:14 gmake[1]: Leaving directory
 '/usr/home/jenkins/workspace/PostGIS_Worker_Run/label/bessie/0c190406e5edf3050c2883cc378e628fbdf26d3e'
 15:08:14 *** Error code 2
 15:08:14
 This has happened before and I think last time I deleted the file in
 /usr/local/include/liblwgeom.h and libwgeom_topo.h
 To fix the issue.  Going to do that again.
 If that fixes it, I think there is something wrong with our config such
 that the system include is being picked up before our local includes.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4638>
