[postgis-tickets] [PostGIS] #4638: bessie failing on GDAL segmentation fault
trac at osgeo.org
Sat Feb 8 12:58:13 PST 2020
Reporter: robe | Owner: robe
Type: defect | Status: assigned
Priority: medium | Milestone: PostGIS 3.0.1
Component: build/upgrade/install | Version: 3.0.x
Resolution: | Keywords:
Description changed by robe:
Old description:
> 15:08:13 passed
> 15:08:13 Test: test_gdal_to_raster ...passed
> 15:08:13 Test: test_gdal_warp ...passed
> 15:08:13 Suite: raster_geometry
> 15:08:13 Test: test_raster_envelope ...passed
> 15:08:13 Test: test_raster_envelope_geom ...gmake[4]: *** [Makefile:78:
> check] Segmentation fault (core dumped)
> 15:08:14 gmake[4]: Leaving directory
> '/usr/home/jenkins/workspace/PostGIS_Worker_Run/label/bessie/0c190406e5edf3050c2883cc378e628fbdf26d3e/raster/test/cunit'
> 15:08:14 gmake[3]: *** [Makefile:19: check-unit] Error 2
> 15:08:14 gmake[3]: Leaving directory
> '/usr/home/jenkins/workspace/PostGIS_Worker_Run/label/bessie/0c190406e5edf3050c2883cc378e628fbdf26d3e/raster/test'
> 15:08:14 gmake[2]: *** [Makefile:66: check-unit] Error 2
> 15:08:14 gmake[2]: Leaving directory
> '/usr/home/jenkins/workspace/PostGIS_Worker_Run/label/bessie/0c190406e5edf3050c2883cc378e628fbdf26d3e/raster'
> 15:08:14 gmake[1]: *** [GNUmakefile:20: check-unit] Error 1
> 15:08:14 gmake[1]: Leaving directory
> '/usr/home/jenkins/workspace/PostGIS_Worker_Run/label/bessie/0c190406e5edf3050c2883cc378e628fbdf26d3e'
> 15:08:14 *** Error code 2
> 15:08:14
> This has happened before and I think last time I deleted the file in
> /usr/local/include/liblwgeom.h and libwgeom_topo.h
> To fix the issue. Going to do that again.
> If that fixes it, I think there is something wrong with our config such
> that the system include is being picked up before our local includes.
New description:
PostgreSQL 11.6, compiled by Visual C++ build 1914, 64-bit
Postgis 3.0.1dev - r0c190406e - 2020-02-08 20:06:10
scripts 3.0.1dev 0c190406e
raster scripts 3.0.1dev 0c190406e
GEOS: 3.8.0-CAPI-1.13.1
PROJ: Rel. 5.2.0, September 15th, 2018
GDAL: GDAL 2.4.2, released 2019/06/28
15:08:13 passed
15:08:14
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4638#comment:1>
