[postgis-tickets] [PostGIS] #4638: bessie failing on GDAL segmentation fault
trac at osgeo.org
Sat Feb 8 12:59:25 PST 2020
Reporter: robe | Owner: robe
Type: defect | Status: assigned
Priority: medium | Milestone: PostGIS 3.0.1
Component: build/upgrade/install | Version: 3.0.x
Resolution: | Keywords:
Description changed by robe:
Old description:
> PostgreSQL 11.6, compiled by Visual C++ build 1914, 64-bit
> Postgis 3.0.1dev - r0c190406e - 2020-02-08 20:06:10
> scripts 3.0.1dev 0c190406e
> raster scripts 3.0.1dev 0c190406e
> GEOS: 3.8.0-CAPI-1.13.1
> PROJ: Rel. 5.2.0, September 15th, 2018
> GDAL: GDAL 2.4.2, released 2019/06/28
> 15:08:13 passed
> 15:08:13 Test: test_gdal_to_raster ...passed
> 15:08:13 Test: test_gdal_warp ...passed
> 15:08:13 Suite: raster_geometry
> 15:08:13 Test: test_raster_envelope ...passed
> 15:08:13 Test: test_raster_envelope_geom ...gmake[4]: *** [Makefile:78:
> check] Segmentation fault (core dumped)
> 15:08:14 gmake[4]: Leaving directory
> '/usr/home/jenkins/workspace/PostGIS_Worker_Run/label/bessie/0c190406e5edf3050c2883cc378e628fbdf26d3e/raster/test/cunit'
> 15:08:14 gmake[3]: *** [Makefile:19: check-unit] Error 2
> 15:08:14 gmake[3]: Leaving directory
> '/usr/home/jenkins/workspace/PostGIS_Worker_Run/label/bessie/0c190406e5edf3050c2883cc378e628fbdf26d3e/raster/test'
> 15:08:14 gmake[2]: *** [Makefile:66: check-unit] Error 2
> 15:08:14 gmake[2]: Leaving directory
> '/usr/home/jenkins/workspace/PostGIS_Worker_Run/label/bessie/0c190406e5edf3050c2883cc378e628fbdf26d3e/raster'
> 15:08:14 gmake[1]: *** [GNUmakefile:20: check-unit] Error 1
> 15:08:14 gmake[1]: Leaving directory
> '/usr/home/jenkins/workspace/PostGIS_Worker_Run/label/bessie/0c190406e5edf3050c2883cc378e628fbdf26d3e'
> 15:08:14 *** Error code 2
> 15:08:14
> This has happened before and I think last time I deleted the file in
> /usr/local/include/liblwgeom.h and libwgeom_topo.h
> To fix the issue. Going to do that again.
> If that fixes it, I think there is something wrong with our config such
> that the system include is being picked up before our local includes.
New description:
https://debbie.postgis.net/job/PostGIS_Worker_Run/label=bessie/1901/consoleFull
15:04:58 PostGIS is now configured for amd64-unknown-freebsd12.0
15:04:58
15:04:58 -------------- Compiler Info -------------
15:04:58 C compiler: cc -std=gnu99 -g -O2 -fno-math-errno
-fno-signed-zeros
15:04:58 C++ compiler (Wagyu): cc -std=c++11 -x c++
15:04:58 CPPFLAGS: -I/usr/local/include
-I/usr/local/include -I/usr/local/include -I/usr/local/include/libxml2
-I/usr/include -I/usr/local/include -I/usr/local/include/json-c
15:04:58 SQL preprocessor: /usr/bin/cpp -traditional-cpp -w -P
15:04:58
15:04:58 -------------- Additional Info -------------
15:04:58 Interrupt Tests: DISABLED use: --with-interrupt-tests to
enable
15:04:58
15:04:58 -------------- Dependencies --------------
15:04:58 GEOS config: /usr/local/bin/geos-config
15:04:58 GEOS version: 3.7.2
15:04:58 GDAL config: /usr/local/bin/gdal-config
15:04:58 GDAL version: 2.4.2
15:04:58 SFCGAL config: /usr/local/bin/sfcgal-config
15:04:58 SFCGAL version: 1.3.6
15:04:58 PostgreSQL config: /usr/local/bin/pg_config
15:04:58 PostgreSQL version: PostgreSQL 11.4
15:04:58 PROJ4 version: 61
15:04:58 Libxml2 config: /usr/local/bin/xml2-config
15:04:58 Libxml2 version: 2.9.9
15:04:58 JSON-C support: yes
15:04:58 protobuf support: yes
15:04:58 protobuf-c version: 1003002
15:04:58 PCRE support: yes
15:04:58 Perl: /usr/local/bin/perl
15:04:58 Wagyu: yes
15:04:58
15:04:58 --------------- Extensions ---------------
15:04:58 PostGIS Raster: enabled
15:04:58 PostGIS Topology: enabled
15:04:58 SFCGAL support: enabled
15:04:58 Address Standardizer support: enabled
15:04:58
15:04:58 -------- Documentation Generation --------
15:04:58 xsltproc: /usr/local/bin/xsltproc
15:04:58 xsl style sheets:
15:04:58 dblatex:
15:04:58 convert: /usr/local/bin/convert
15:04:58 mathml2.dtd:
http://www.w3.org/Math/DTD/mathml2/mathml2.dtd
15:04:58
15:08:13 passed
15:08:14
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4638#comment:2>
