[postgis-tickets] [PostGIS] #4618: ST_Buffer(geography) issue
trac at osgeo.org
Tue Feb 11 14:52:23 PST 2020
Reporter: olehz | Owner: pramsey
Type: defect | Status: closed
Priority: medium | Milestone: PostGIS 3.0.1
Component: postgis | Version: 3.0.x
Resolution: wontfix | Keywords: ST_Buffer
Changes (by robe):
* status: new => closed
* resolution: => wontfix
Comment:
ST_Buffer in geography is not a native function. It piggy backs on
geometry ST_Buffer and in doing so chooses a best guess spatial reference
system for the point before applying the buffer. That said for large
buffers, its going to have more and more errors as your buffer size grows.
This is not a bug just an implementation limitation. As noted in the docs
- http://postgis.net/docs/manual-3.0/ST_Buffer.html all assumptions full
apart with large buffers.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4618#comment:2>
