[postgis-tickets] [PostGIS] #4462: st_asmvtgeom fails with IllegalArgumentException: RobustDeterminant encountered non-finite numbers
PostGIS trac at osgeo.org
Tue Feb 11 23:25:25 PST 2020
  Reporter:  autra       |      Owner:  pramsey
      Type:  defect      |     Status:  closed
  Priority:  medium      |  Milestone:  PostGIS 2.5.3
 Component:  postgis     |    Version:  2.5.x
Resolution:  worksforme  |   Keywords:
Comment (by autra):
 I'm allowing an additional comment for anyone passing by: to fix this, you
 must either update libgeos or postgis (to v3). However, if you are on
 debian buster, beware that you only have postgis-3 package for postgresql
 12. BUT also beware that the gdal version buster ships with is currently
 not compatible with postgresql12 (we need
 https://github.com/OSGeo/gdal/commit/963618e77de4eee5e7321f5f5ca7abc2b7287fa2
 and the 2.4 version in buster doesn't have that)!
 So if you also need gdal, your only choice as of now is to use pgdg
 repository and install postgresql-11-postgis-3 from there.
 It's a pity that the only broken tuple of versions are precisely the one
 that ships in buster... I'm not sure what would be the less costly
 solution for this though.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4462#comment:10>
