[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0alpha1-7-gabc6fd7
Wed Feb 12 03:07:36 PST 2020
the project "PostGIS".
       via  abc6fd77a8240fe673f5a012a97eb62a950f085e (commit)
      from  4c0a0b5665019832f502cd3dfa4286137f02db3e (commit)
revisions in full, below.
commit abc6fd77a8240fe673f5a012a97eb62a950f085e
Author: Sandro Santilli <strk at kbt.io>
Date:   Wed Feb 12 12:05:53 2020 +0100
    Stub a "postgis" command
diff --git a/.gitignore b/.gitignore
index cd76069..c4388f9 100644
--- a/.gitignore
+++ b/.gitignore
@@ -92,6 +92,7 @@ loader/cunit/cu_tester
 loader/cunit/Makefile
 loader/Makefile
 loader/pgsql2shp
+loader/postgis
 loader/shp2pgsql
 loader/shp2pgsql-gui
 ltmain.sh
diff --git a/loader/Makefile.in b/loader/Makefile.in
index e6d1af0..96e05d7 100644
--- a/loader/Makefile.in
+++ b/loader/Makefile.in
@@ -29,6 +29,7 @@ INSTALL = @INSTALL@
 LIBTOOL = @LIBTOOL@
 # Filenames with extension as determined by the OS
+POSTGIS-CLI=postgis at EXESUFFIX@
 PGSQL2SHP-CLI=pgsql2shp at EXESUFFIX@
 SHP2PGSQL-CLI=shp2pgsql at EXESUFFIX@
 SHP2PGSQL-GUI=shp2pgsql-gui at EXESUFFIX@
@@ -75,7 +76,7 @@ gtk_build = @GTK_BUILD@
 SHPLIB_OBJS = shpopen.o dbfopen.o getopt.o shpcommon.o safileio.o
 # The real parts of the Makefile
-all: $(SHP2PGSQL-CLI) $(PGSQL2SHP-CLI) @GTK_BUILD@
+all: $(SHP2PGSQL-CLI) $(PGSQL2SHP-CLI) $(POSTGIS-CLI) @GTK_BUILD@
 gui: $(SHP2PGSQL-GUI) $(SHP2PGSQL-CLI) @GTK_WIN32_RES@
@@ -100,6 +101,9 @@ $(PGSQL2SHP-CLI): $(SHPLIB_OBJS) pgsql2shp-core.o pgsql2shp-cli.o $(LIBLWGEOM)
 	$(LIBTOOL) --mode=link \
 	  $(CC) $(CFLAGS) $^ $(LDFLAGS) $(ICONV_LDFLAGS) $(PGSQL_FE_LDFLAGS) $(GETTEXT_LDFLAGS) -o $@
+$(POSTGIS-CLI): postgis.sh
+	cp postgis.sh postgis; chmod +x postgis
 $(SHP2PGSQL-CLI): $(SHPLIB_OBJS) shp2pgsql-core.o shp2pgsql-cli.o $(LIBLWGEOM)
 	  $(CC) $(CFLAGS) $^ -o $@ $(LDFLAGS) $(GETTEXT_LDFLAGS) $(ICONV_LDFLAGS)
@@ -152,6 +156,7 @@ uninstall: uninstall-desktop uninstall-icons
 	$(LIBTOOL) --mode=uninstall rm -f "$(DESTDIR)$(bindir)/$(PGSQL2SHP-CLI)"
 	$(LIBTOOL) --mode=uninstall rm -f "$(DESTDIR)$(bindir)/$(SHP2PGSQL-CLI)"
 	$(LIBTOOL) --mode=uninstall rm -f "$(DESTDIR)$(bindir)/$(SHP2PGSQL-GUI)"
+	$(LIBTOOL) --mode=uninstall rm -f "$(DESTDIR)$(bindir)/$(POSTGIS-CLI)"
 # TODO: move here what's currently run from regress/loader and
 # regress/dumper ?
diff --git a/loader/postgis.sh b/loader/postgis.sh
new file mode 100644
index 0000000..bb634c9
--- /dev/null
+++ b/loader/postgis.sh
@@ -0,0 +1,96 @@
+#!/bin/sh
+usage() {
+  echo "Usage: $0 <command> [<args>]"
+  echo "Commands:"
+  echo "  help               print this message and exits"
+  echo "  enable <database>  enable postgis in given database"
+  echo "  upgrade <database>  enable postgis in given database"
+  echo "  status <database>  prints postgis status in given database"
+enable() {
+  db="$1"; shift
+  test -n "$db" || {
+    echo "Please specify a database name" >&2
+    return 1
+  echo "Enable is not implemented yet" >&2
+  return 1
+upgrade() {
+  db="$1"; shift
+    return 1
+  echo "Upgrade is not implemented yet" >&2
+  return 1
+status() {
+  test -n "$1" || {
+    echo "Please specify at least a database name" >&2
+    return 1
+  for db in $@; do
+    SCHEMA=`cat <<EOF | psql -XtA ${db}
+SELECT n.nspname
+  FROM pg_namespace n, pg_proc p
+  WHERE n.oid = p.pronamespace
+    AND p.proname = 'postgis_full_version'
+EOF
+    if test -z "$SCHEMA"; then
+      echo "db $db does not have postgis enabled"
+      continue
+    fi
+    FULL_VERSION=`cat <<EOF | psql -XtA ${db}
+SELECT ${SCHEMA}.postgis_full_version()
+EOF
+    #POSTGIS="3.1.0dev r3.1.0alpha1-3-gfc5392de7"
+    VERSION=`echo "$FULL_VERSION" | sed 's/POSTGIS="\([^ ]*\).*/\1/'`
+    EXTENSION=
+    if expr "$FULL_VERSION" : '.*\[EXTENSION\]' > /dev/null; then
+      EXTENSION=" as extension"
+    fi
+    NEED_UPGRADE=
+    if expr "$FULL_VERSION" : '.*need upgrade' > /dev/null; then
+      NEED_UPGRADE=" - NEEDS UPGRADE"
+    fi
+    echo "db $db has postgis ${VERSION}${EXTENSION} in schema ${SCHEMA}${NEED_UPGRADE}"
+  done
+test -n "$1" || {
+  usage >&2
+  exit 1
+while test -n "$1"; do
+  if test "$1" = "help"; then
+    usage 0
+  elif test "$1" = "enable"; then
+    shift
+    enable $@
+    exit $?
+  elif test "$1" = "upgrade"; then
+    shift
+    upgrade $@
+    exit $?
+  elif test "$1" = "status"; then
+    shift
+    status $@
+    exit $?
+  else
+    echo "Unrecognized command: $1" >&2
+    usage >&2
+    exit 1
+  fi
+  shift
+done
Summary of changes:
 .gitignore         |  1 +
 loader/Makefile.in |  7 +++-
 loader/postgis.sh  | 96 ++++++++++++++++++++++++++++++++++++++++++++++++++++++
 3 files changed, 103 insertions(+), 1 deletion(-)
 create mode 100644 loader/postgis.sh
hooks/post-receive
