[postgis-tickets] [PostGIS] #4639: Can't upgrade from 3.0.0alpha3 to 3.1.0dev (cannot drop function pgis_geometry_union_transfn)
trac at osgeo.org
Wed Feb 12 06:58:01 PST 2020
Reporter: strk | Owner: pramsey
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 3.1.0
Component: postgis | Version: master
Keywords: upgrade |
strk=# select postgis_full_version();
POSTGIS="3.1.0dev r3.1.0alpha1-7-g9a939fdae" [EXTENSION] PGSQL="96"
GEOS="3.9.0dev-CAPI-1.14.0" SFCGAL="1.3.6" PROJ="7.0.0" GDAL="GDAL 3.0.4,
released 2020/01/28" LIBXML="2.9.4" LIBJSON="0.12.1" LIBPROTOBUF="1.2.1"
WAGYU="0.4.3 (Internal)" (core procs from "3.0.0alpha3dev r17535" need
upgrade) TOPOLOGY (topology procs from "3.0.0alpha5dev r17729" need
upgrade) [UNPACKAGED!] RASTER (raster procs from "3.0.0alpha3dev r17535"
need upgrade) (sfcgal procs from "3.0.0alpha3dev r17535" need upgrade)
strk=# ALTER EXTENSION postgis UPDATE TO "3.1.0dev";
ERROR: cannot drop function
pgis_geometry_union_transfn(internal,geometry) because other objects
depend on it
DETAIL: function st_union(geometry) depends on function
HINT: Use DROP ... CASCADE to drop the dependent objects too.
See also #4483 (please let's fix upgrade issues!)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4639>
