[postgis-tickets] [PostGIS] #4483: Can't upgrade from PostGIS 3.0.0alpha3 to 3.0.0alpha4 or 3.0.0alpha5dev (ST_AsGeoJSON)
trac at osgeo.org
Wed Feb 12 04:05:18 PST 2020
(ST_AsGeoJSON)
Reporter: robe | Owner: pramsey
Type: defect | Status: reopened
Priority: blocker | Milestone: PostGIS 3.0.1
Component: postgis | Version: master
Resolution: | Keywords:
Comment (by strk):
This query returns nothing:
SELECT p.oid as oid,
n.nspname as schema,
n.oid as schema_oid,
p.proname as name,
pg_catalog.pg_get_function_arguments(p.oid) as arguments,
pg_catalog.pg_get_function_identity_arguments(p.oid) as
identity_arguments
FROM pg_catalog.pg_proc p
LEFT JOIN pg_catalog.pg_namespace n ON n.oid = p.pronamespace
WHERE
n.oid = (
SELECT n.oid
FROM pg_proc p
JOIN pg_namespace n ON p.pronamespace = n.oid
WHERE proname = 'postgis_full_version'
) AND
LOWER(p.proname) = 'st_asgeojson' AND
LOWER(pg_catalog.pg_get_function_arguments(p.oid)) ~ LOWER('r
record, geom_column text, maxdecimaldigits integer, pretty_print boolean')
AND
pg_catalog.pg_function_is_visible(p.oid);
The problem is that pg_get_function_arguments includes also the default
values in my case:
arguments | r record, geom_column text DEFAULT
''::text, maxdecimaldigits integer DEFAULT 15, pretty_print boolean
DEFAULT false
pg_get_function_identity_arguments | r record, geom_column text,
But the _drop_if_needed is using the pg_catalog.pg_get_function_arguments
function instead of the pg_catalog.pg_get_function_identity_arguments to
find a match!
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4483#comment:31>
