[postgis-tickets] [PostGIS] #4483: Can't upgrade from PostGIS 3.0.0alpha3 to 3.0.0alpha4 or 3.0.0alpha5dev (ST_AsGeoJSON)
PostGIS trac at osgeo.org
Wed Feb 12 04:07:03 PST 2020
(ST_AsGeoJSON)
  Reporter:  robe     |      Owner:  pramsey
      Type:  defect   |     Status:  reopened
  Priority:  blocker  |  Milestone:  PostGIS 3.0.1
 Component:  postgis  |    Version:  master
Resolution:           |   Keywords:
Comment (by strk):
 This patch fixes it for me:
 Raul: do you see anything wrong with it ?
 diff --git a/postgis/postgis_before_upgrade.sql
 b/postgis/postgis_before_upgrade.sql
 index 0a5f26696..1aacf9168 100644
 --- a/postgis/postgis_before_upgrade.sql
 +++ b/postgis/postgis_before_upgrade.sql
 @@ -57,7 +57,7 @@ BEGIN
                                         WHERE proname =
 'postgis_full_version'
                                         ) AND
                                 LOWER(p.proname) = LOWER(function_name)
 AND
 LOWER(pg_catalog.pg_get_function_arguments(p.oid)) ~
 LOWER(function_arguments) AND
 LOWER(pg_catalog.pg_get_function_identity_arguments(p.oid)) ~
                                 pg_catalog.pg_function_is_visible(p.oid)
                         ORDER BY 1, 2, 4
         LOOP
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4483#comment:32>
