[postgis-tickets] [PostGIS] #4483: Can't upgrade from PostGIS 3.0.0alpha3 to 3.0.0alpha4 or 3.0.0alpha5dev (ST_AsGeoJSON)
trac at osgeo.org
Wed Feb 12 04:15:43 PST 2020
(ST_AsGeoJSON)
Reporter: robe | Owner: pramsey
Type: defect | Status: reopened
Priority: blocker | Milestone: PostGIS 3.0.1
Component: postgis | Version: master
Resolution: | Keywords:
Comment (by Algunenano):
> Raul: do you see anything wrong with it ?
Yes, we use `pg_get_function_arguments` because we do want the default
values in the signature, so we drop the function when the defaults change
and not always.
I see that the signature to drop was changed in
https://trac.osgeo.org/postgis/changeset/17879, probably because there was
more than one issue with the changes and multiple drops where needed and
we have switched back and forth.
The solution is to add a new line readding what was removed in r17879
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4483#comment:34>
