[postgis-tickets] [PostGIS] #4642: regress_proj test fails with PROJ 7.0.0
trac at osgeo.org
Fri Feb 21 02:35:33 PST 2020
Reporter: Bas Couwenberg | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.0.1
Component: postgis | Version: 3.0.x
Resolution: | Keywords:
Comment (by Algunenano):
The offending SRID is 4138:
ELECT ST_AsEWKT(ST_Transform('SRID=4326; POINT(0 0)'::geometry, 4138));
ERROR: transform: failed to load datum shift file (-38)
Select * from spatial_ref_sys where srid = 4138;
srid | auth_name | auth_srid |
srtext
proj4text
4138 | EPSG | 4138 | GEOGCS["St. George
Island",DATUM["St_George_Island",SPHEROID["Clarke 1866",6378206.4,294.9786
982138982,AUTHORITY["EPSG","7008"]],AUTHORITY["EPSG","6138"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],UNIT["degree",0.
0174532925199433,AUTHORITY["EPSG","9122"]],AUTHORITY["EPSG","4138"]] |
+proj=longlat +ellps=clrk66 +no_defs
(1 row)
With PROJ6 and datum-grid:
SELECT ST_AsEWKT(ST_Transform('SRID=4326; POINT(0 0)'::geometry, 4138));
st_asewkt
SRID=4138;POINT(Infinity Infinity)
(1 row)
I don't know if that was transformation is even supposed to work.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4642#comment:5>
