[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0alpha1-12-gd1082f7
git at osgeo.org
git at osgeo.org
Sat Feb 22 15:32:41 PST 2020
the project "PostGIS".
via d1082f700c3b68edd77db1515804976aca5f7027 (commit)
from 07d4cef8c29dfbe0bd51b488292d234f62ee1a9b (commit)
revisions in full, below.
commit d1082f700c3b68edd77db1515804976aca5f7027
Author: Darafei Praliaskouski <me at komzpa.net>
Date: Sun Feb 23 02:32:29 2020 +0300
Notes after getting release done
diff --git a/HOWTO_RELEASE b/HOWTO_RELEASE
index 62eb2d9..33095cf 100644
--- a/HOWTO_RELEASE
+++ b/HOWTO_RELEASE
@@ -1,6 +1,6 @@
How to release
-Date: 2019-10-28
+Date: 2019-02-23
Versioning Scheme
@@ -45,7 +45,9 @@ documentation -- that means having the required software:
* For PostGIS:
- PostgreSQL
- GEOS
- - Proj4
+ - Proj
+ - SFCGAL
+ - protobuf-c
- GDAL (for raster)
- json-c (for GeoJSON load support)
* For the docs:
@@ -57,23 +59,44 @@ documentation -- that means having the required software:
Release procedure
-- For first micro of a minor, make sure to pull the latest translations from transifex
- TODO: more detail here - there is a job on debbie for 3.1 for examples
- https://debbie.postgis.net/view/PostGIS/job/PostGIS_docs_translations_3.1
- and she's setup with an api key to pull and push translations.
-- Ensure all bots are green: https://trac.osgeo.org/postgis
-- Edit NEWS: set release date and check all notable changes have
- been reported (extract from git log).
-- Edit README.postgis and set release date and version.
-- Add release notes in doc/release_notes.xml
-- Update Version.config to drop the "dev" suffix
-- Add the "dev" suffixed version in extensions/upgradeable_versions.mk
- and ensure all the previous released minor versions are listed in it
-- Update the README.md to reflect new to be created buildbot badges
- (this should only be needed for trunk release)
-- Commit all changes
-- If this is a minor or major release (no branch exists):
+1. Check access.
+ - Can edit tickets and milestones on http://trac.osgeo.org/postgis/
+ - Can commit to upstream git https://git.osgeo.org/gitea/postgis/postgis
+ - Have SSH to download.osgeo.org and can write to /osgeo/download/postgis.
+ - Have SSH to postgis.net and can write to /etc/nginx/sites-enabled/postgis.net.
+ - Post to https://git.osgeo.org/gitea/postgis/postgis.net/ and get it added to feed
+ https://planet.postgresql.org/register/new/
+ - Can alter https://debbie.postgis.net
+2. Check greenlight.
+ - Ensure all bots are green: https://trac.osgeo.org/postgis
+ - Check no blockers on https://trac.osgeo.org/postgis/roadmap on version you're releasing.
+3. Reconcile done & planned.
+ - Edit NEWS: set release date and check all notable changes have been reported
+ (extract from git log and trac tickets for milestone).
+ - Create milestone for next verison in Trac.
+ - Push all the open tickets in Trac milestone to future and Fund Me milestones.
+4. Update code.
+ - For first micro of a minor, make sure to pull the latest translations from transifex
+ TODO: more detail here - there is a job on debbie for 3.1 for examples
+ https://debbie.postgis.net/view/PostGIS/job/PostGIS_docs_translations_3.1
+ and she's setup with an api key to pull and push translations.
+ - Update the README.md to reflect new to be created buildbot badges
+ (this should only be needed for trunk release)
+ - Edit README.postgis and set release date and version.
+ - Add release notes in doc/release_notes.xml
+ - Update Version.config to drop the "dev" suffix
+ - Add the "dev" suffixed version in extensions/upgradeable_versions.mk
+ and ensure all the previous released minor versions are listed in it
+ - Commit all changes
+ - If this is a minor or major release (no branch exists):
$ rev=x.x
$ git checkout master; git checkout -b "$rev"; git push -u osgeo $rev
@@ -84,36 +107,54 @@ Release procedure
Go to: https://trac.osgeo.org/postgis/ edit the matrix to reflect new branch
-- Tag branch: (replace x.x and x.x.x with minor and micro version e.g 2.3, 2.3.1
- $ rev=x.x.x
- $ git tag -a $rev -m "Tagged release $rev"; git push osgeo --tags
-- Run: sh make_dist.sh $rev (note, debbie should have already done this,
- and the file will be waiting in postgis.net/stuff. You might need to wait a few minutes to see it.)
- If impatient check status of job - https://debbie.postgis.net/job/PostGIS_Make_Dist/
-- Documentation should also have been built and should be in postgis.net/stuff
- (this sometimes takes sometime so wait 15 minutes)
-- Test generated tarball (including extension upgrade)
-- Copy tarball, pdf, doc-html.. to https://download.osgeo.org/postgis/ web site and edit postgis.net/source page
-- Announce on e-mail
- - postgis-users
- - postgis-devel
- - pgsql-announce (send email just to them, not with other ccs, they reject if others in cc)
- - send note to david at fetter dot org to be included in Weekly news
- - osgeo-discuss
-- Update web sites
- - PostGIS News
- - https://git.osgeo.org/gitea/postgis/postgis.net/src/master/_content/posts
- a) create a new Post for current year making sure the page name starts with mm-dd
- b) Update links on https://git.osgeo.org/gitea/postgis/postgis.net/src/master/_content/pages/source.html
- c) commit and wait 5 minutes to see changes on website
- - PostGIS doc release versioned doc - http://postgis.net/documentation/
+5. Publish release
+ - Check that bots are still green on https://trac.osgeo.org/postgis
+ - Tag branch: (replace x.x and x.x.x with minor and micro version e.g 2.3, 2.3.1)
+ $ rev=x.x.x
+ $ git tag -a $rev -m "Tagged release $rev"
+ $ git push osgeo --tags
+ - Take tar ball from http://postgis.net/stuff/
+ (You might need to wait a few minutes to see it.
+ If impatient check status of job - https://debbie.postgis.net/job/PostGIS_Make_Dist/
+ If it fails, sh make_dist.sh $rev)
+ - Documentation should also have been built and should be in http://postgis.net/stuff
+ (this sometimes takes sometime so wait 15 minutes)
+ - Test generated tarball (including extension upgrade)
+ - Copy tarball, pdf, doc-html to https://download.osgeo.org/postgis/ web site.
+ - PostGIS doc release versioned doc - http://postgis.net/documentation/
- On postgis.net server, change /etc/nginx/sites-enabled/postgis.net (Versionless URL line )
- nginx -t #to confirm you didn't breat the config
- service nginx reload
- Verify the documentation is up to date (might need to change the apach config)
- - Wikipedia
+ Verify the documentation is up to date (might need to change the apache config)
+ - Post on website:
+ - https://git.osgeo.org/gitea/postgis/postgis.net/src/branch/master/_content/config.yml
+ Fix latest version pointers.
+ - https://git.osgeo.org/gitea/postgis/postgis.net/src/master/_content/posts
+ a) create a new Post for current year making sure the page name starts with mm-dd
+ b) Update links on https://git.osgeo.org/gitea/postgis/postgis.net/src/master/_content/pages/source.html
+ c) commit and wait 5 minutes to see changes on website
+6. Spread the word
+ - Announce on e-mail
+ - postgis-users at lists.osgeo.org
+ - postgis-devel at lists.osgeo.org
+ - discuss at lists.osgeo.org
+ - pgsql-announce at postgresql.org (send email just to them, not with other ccs, they reject if others in cc)
+ - david at fetter.org to be included in Weekly news
+ - External web sites
+ - Wikipedia https://en.wikipedia.org/wiki/PostGIS
+ - Wikidata https://www.wikidata.org/wiki/Q1569955
- Twitter
This should automatically happen as a result of posting to PostGIS website since Planet PostGIS and Planet PostgreSQL both autotweet.
-- Update Trac and make old Milestone as completed
-- Push the revision number forward (see Versioning Scheme)
-- Remove the "dev" suffixed version from extensions/upgradeable_versions.mk
+7. Start new development cycle
+ - Update Trac and make old Milestone as completed
+ - Push the revision number forward (see Versioning Scheme)
+ - Remove the "dev" suffixed version from extensions/upgradeable_versions.mk
diff --git a/raster/Version.config b/raster/Version.config
deleted file mode 100644
index faac75b..0000000
--- a/raster/Version.config
+++ /dev/null
@@ -1,8 +0,0 @@
-# Version numbering central repository, to be included from various
-# places during the build process
-# See HOWTO_RELEASE file in SVN for definitions of those three.
-POSTGIS_RASTER_MAJOR_VERSION=0
-POSTGIS_RASTER_MINOR_VERSION=1
-POSTGIS_RASTER_MICRO_VERSION=6d
Summary of changes:
HOWTO_RELEASE | 135 ++++++++++++++++++++++++++++++++------------------
raster/Version.config | 8 ---
2 files changed, 88 insertions(+), 55 deletions(-)
delete mode 100644 raster/Version.config
hooks/post-receive
