[postgis-tickets] [PostGIS] #4643: PostgreSQL 13 no longer supports FROM in CREATE EXTENSION
PostGIS trac at osgeo.org
Sat Feb 22 19:58:31 PST 2020
 Reporter:  robe     |      Owner:  pramsey
     Type:  defect   |     Status:  new
 Priority:  blocker  |  Milestone:  PostGIS 3.1.0
Component:  postgis  |    Version:  master
 Keywords:           |
 Looks like our postgis 3.1 is broken again by PostgreSQL change upstream.
 Debbie is showing this error on 3.1.0 (master) run
 19:10:38 ERROR:  CREATE EXTENSION ... FROM is no longer supported
 19:10:38 LINE 1: CREATE EXTENSION postgis VERSION '3.1.0dev' FROM
 unpackaged
 This must be a test we don't run in the test run after postgresql is
 rebuilt since it didn't error there.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4643>
