[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0alpha1-13-g3902e14
git at osgeo.org
git at osgeo.org
Mon Feb 24 02:55:33 PST 2020
the project "PostGIS".
via 3902e1442149f642ab2b6506388dc63ce73208f2 (commit)
from d1082f700c3b68edd77db1515804976aca5f7027 (commit)
revisions in full, below.
commit 3902e1442149f642ab2b6506388dc63ce73208f2
Author: Raúl Marín <git at rmr.ninja>
Date: Mon Feb 24 11:54:27 2020 +0100
regress_proj: Avoid testing with points out of the srs boundaries
The behaviour has changed in PROJ 7 and it now returns an error
(before it returned 'Infinity Infinity').
References #4642
diff --git a/regress/core/regress_proj.sql b/regress/core/regress_proj.sql
index 411d1b9..70ea5ed 100644
--- a/regress/core/regress_proj.sql
+++ b/regress/core/regress_proj.sql
@@ -63,5 +63,5 @@ SELECT 13, count(*) FROM
SELECT ST_Transform('SRID=4326; POINT(0 0)'::geometry, srid) AS g
FROM
- ( SELECT srid FROM spatial_ref_sys LIMIT 150 ) _a
+ ( Select srid from spatial_ref_sys where srid IN (3819, 3821, 3824, 3889, 3906, 4001, 4002, 4003, 4004, 4005, 4006, 4007, 4008, 4009, 4010, 4011, 4012, 4013, 4014, 4015, 4016, 4018, 4019, 4020, 4021, 4022, 4023, 4024, 4025, 4027, 4028, 4029, 4030, 4031, 4032, 4033, 4034, 4035, 4036, 4041, 4042, 4043, 4044, 4045, 4046, 4047, 4052, 4053, 4054, 4055, 4075, 4081, 4120, 4121, 4122, 4123, 4124, 4125, 4126, 4127, 4128, 4129, 4130, 4131, 4132, 4133, 4134, 4135, 4139, 4140, 4141, 4142, 4143, 4144, 4145, 4146, 4147, 4148, 4149, 4150, 4151, 4152, 4153, 4154, 4155, 4156, 4157, 4158, 4159, 4160, 4161, 4162, 4163, 4164, 4165, 4166, 4167, 4168, 4169, 4170, 4171, 4172, 4173, 4174, 4175, 4176, 4178, 4179, 4180, 4181, 4182, 4183, 4184, 4185, 4188, 4189, 4190, 4191, 4192, 4193, 4194, 4195, 4196, 4197, 4198, 4199, 4200, 4201, 4202, 4203, 4204, 4205, 4206, 4207, 4
208, 4209, 4210, 4211, 4212, 4213, 4214, 4215, 4216, 4218, 4219, 4220, 4221)) _a
) _b WHERE g IS NOT NULL;
diff --git a/regress/core/regress_proj_expected b/regress/core/regress_proj_expected
index b8b5160..73058e6 100644
--- a/regress/core/regress_proj_expected
+++ b/regress/core/regress_proj_expected
@@ -11,4 +11,4 @@ ERROR: ST_Transform: Input geometry has unknown (0) SRID
10|POINT(574600 5316780)
11|SRID=100001;POINT(574600 5316780)
ERROR: could not parse proj string 'invalid projection'
-13|150
+13|147
Summary of changes:
regress/core/regress_proj.sql | 2 +-
regress/core/regress_proj_expected | 2 +-
2 files changed, 2 insertions(+), 2 deletions(-)
hooks/post-receive
