[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0alpha1-18-g7e5a323
git at osgeo.org
git at osgeo.org
Thu Feb 27 01:01:11 PST 2020
the project "PostGIS".
via 7e5a3233d7437dabe80733a343e9444c9936d4e0 (commit)
from 9e40e8e35795fab1553e52711a6f83d832dc62ba (commit)
revisions in full, below.
commit 7e5a3233d7437dabe80733a343e9444c9936d4e0
Author: Sandro Santilli <strk at kbt.io>
Date: Thu Feb 27 10:00:43 2020 +0100
Add the sql target for postgis_topology extension
simplifies directory creation and improve `make` concurrency
diff --git a/extensions/postgis_topology/Makefile.in b/extensions/postgis_topology/Makefile.in
index 3b271a4..13de422 100644
--- a/extensions/postgis_topology/Makefile.in
+++ b/extensions/postgis_topology/Makefile.in
@@ -51,12 +51,13 @@ $(EXTENSION).control: $(EXTENSION).control.in Makefile
| sed -e 's|@EXTVERSION@|$(EXTVERSION)|g' \
-sql/$(EXTENSION)--$(EXTVERSION).sql: sql/$(EXTENSION).sql
- mkdir -p sql
+sql:
+ mkdir -p $@
+sql/$(EXTENSION)--$(EXTVERSION).sql: sql/$(EXTENSION).sql | sql
cp $< $@
-sql/$(EXTENSION).sql: extlock.sql sql_bits/topology.sql sql_bits/mark_editable_objects.sql.in sql_bits/topology_comments.sql
- mkdir -p sql
+sql/$(EXTENSION).sql: extlock.sql sql_bits/topology.sql sql_bits/mark_editable_objects.sql.in sql_bits/topology_comments.sql | sql
cat $^ > $@
#strip BEGIN/COMMIT since these are not allowed in extensions
@@ -71,8 +72,7 @@ sql_bits/topology.sql: ../../topology/topology.sql
sql_bits/topology_comments.sql: ../../doc/topology_comments.sql
cp $< $@
-sql/$(EXTENSION)--unpackaged--$(EXTVERSION).sql: ../../topology/topology.sql ../../utils/create_unpackaged.pl sql/topology_upgrade.sql Makefile
- mkdir -p sql
+sql/$(EXTENSION)--unpackaged--$(EXTVERSION).sql: ../../topology/topology.sql ../../utils/create_unpackaged.pl sql/topology_upgrade.sql Makefile | sql
# Ugprade before packaging
cat sql/topology_upgrade.sql > $@
cat $< | $(PERL) ../../utils/create_unpackaged.pl postgis_topology >> $@
@@ -85,8 +85,7 @@ sql/$(EXTENSION)--unpackaged--$(EXTVERSION).sql: ../../topology/topology.sql ../
#aggregates are special
#they can be dropped but we need to remove
#them from the extension first
-sql/topology_upgrade.sql: ../../topology/topology_upgrade.sql
- mkdir -p sql
+sql/topology_upgrade.sql: ../../topology/topology_upgrade.sql | sql
sed -e 's/BEGIN;//g' -e 's/COMMIT;//g' -e '/^CREATE SCHEMA/d;' $< > $@
sql/$(EXTENSION)--ANY--$(EXTVERSION).sql: $(EXTENSION_UPGRADE_SCRIPTS)
Summary of changes:
extensions/postgis_topology/Makefile.in | 15 +++++++--------
1 file changed, 7 insertions(+), 8 deletions(-)
hooks/post-receive
