[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0alpha1-19-g9ed7d84
git at osgeo.org
git at osgeo.org
Thu Feb 27 08:00:19 PST 2020
the project "PostGIS".
via 9ed7d8436b902f6086b54e753006bd14a87aba4d (commit)
from 7e5a3233d7437dabe80733a343e9444c9936d4e0 (commit)
revisions in full, below.
commit 9ed7d8436b902f6086b54e753006bd14a87aba4d
Author: Sandro Santilli <strk at kbt.io>
Date: Thu Feb 27 16:59:29 2020 +0100
Further simplification and unification of extension Makefiles
diff --git a/extensions/postgis/Makefile.in b/extensions/postgis/Makefile.in
index 9acf25e..ef7a451 100644
--- a/extensions/postgis/Makefile.in
+++ b/extensions/postgis/Makefile.in
@@ -55,7 +55,7 @@ EXTENSION_UPGRADE_SCRIPTS = \
# Scripts making up the extension upgrade-from-unpackaged file
# NOTE: order matters
EXTENSION_UNPACKAGED_UPGRADE_SCRIPTS = \
- sql/postgis.sql
+ sql/$(EXTENSION)--$(EXTVERSION).sql
RASTER_DROP_SCRIPTS = \
../../raster/rt_pg/rtpostgis_upgrade_cleanup.sql \
@@ -68,10 +68,6 @@ CURV_big=@POSTGIS_MAJOR_VERSION@@POSTGIS_MINOR_VERSION@
all: sql/$(EXTENSION)--$(EXTVERSION).sql sql/$(EXTENSION)--unpackaged--$(EXTVERSION).sql sql/$(EXTENSION)--ANY--$(EXTVERSION).sql
-sql/$(EXTENSION).sql: $(EXTENSION_SCRIPTS) | sql
- printf '\\echo Use "CREATE EXTENSION $(EXTENSION)" to load this file. \\quit\n' > $@
- cat $^ >> $@
$(EXTENSION).control: $(EXTENSION).control.in Makefile
cat $< \
| sed -e 's|@EXTVERSION@|$(EXTVERSION)|g' \
@@ -95,8 +91,9 @@ sql/raster_unpackage.sql: $(RASTER_DROP_SCRIPTS) | sql
sed -ne '/UNPACKAGE_CODE/{s///; :a' -e 'n;p;ba' -e '}' \
unpackage_raster_if_needed.sql >> $@
-sql/$(EXTENSION)--$(EXTVERSION).sql: sql/$(EXTENSION).sql | sql
- cp $< $@
+sql/$(EXTENSION)--$(EXTVERSION).sql: $(EXTENSION_SCRIPTS) | sql
+ printf '\\echo Use "CREATE EXTENSION $(EXTENSION)" to load this file. \\quit\n' > $@
+ cat $^ >> $@
sql/$(EXTENSION)--unpackaged--$(EXTVERSION).sql: $(EXTENSION_UNPACKAGED_UPGRADE_SCRIPTS) sql/$(EXTENSION)--ANY--$(EXTVERSION).sql ../../utils/create_unpackaged.pl Makefile | sql
# Ensure version is correct
diff --git a/extensions/postgis_raster/Makefile.in b/extensions/postgis_raster/Makefile.in
index 5ccbfe0..856c956 100644
--- a/extensions/postgis_raster/Makefile.in
+++ b/extensions/postgis_raster/Makefile.in
@@ -52,7 +52,7 @@ EXTENSION_UPGRADE_SCRIPTS = \
- sql/rtpostgis.sql
EXTRA_CLEAN = sql
@@ -63,10 +63,6 @@ all: sql/$(EXTENSION)--$(EXTVERSION).sql sql/$(EXTENSION)--unpackaged--$(EXTVERS
sql:
mkdir -p $@
- cat $^ >> $@
cat $< \
@@ -74,8 +70,9 @@ $(EXTENSION).control: $(EXTENSION).control.in Makefile
| sed -e 's|@MODULEPATH@|$(MODULEPATH)|g' \
- cp $< $@
+ cat $^ >> $@
sql/$(EXTENSION)--unpackaged--$(EXTVERSION).sql: $(EXTENSION_UNPACKAGED_UPGRADE_SCRIPTS) ../../utils/create_unpackaged.pl sql/$(EXTENSION)--ANY--$(EXTVERSION).sql Makefile | sql
diff --git a/extensions/postgis_sfcgal/Makefile.in b/extensions/postgis_sfcgal/Makefile.in
index e50e8bf..8d60983 100644
--- a/extensions/postgis_sfcgal/Makefile.in
+++ b/extensions/postgis_sfcgal/Makefile.in
@@ -39,8 +39,13 @@ EXTENSION_UNPACKAGED_UPGRADE_SCRIPTS = \
sql_bits/sfcgal.sql \
+EXTENSION_SCRIPTS = \
+ sql_bits/sfcgal_comments.sql \
+ sql_bits/sfcgal.sql
EXTRA_CLEAN = sql
sql:
@@ -51,21 +56,9 @@ $(EXTENSION).control: $(EXTENSION).control.in Makefile
- mkdir -p sql
- cp $< $@
-sql/$(EXTENSION).sql: sql_bits/sfcgal.sql sql_bits/sfcgal_comments.sql
- mkdir -p sql
- cat $^ > $@
-#this is a cludge to allow upgrading from same SVN to same SVN
-sql/$(EXTENSION)--$(EXTVERSION)--$(EXTVERSION)next.sql: sql_bits/sfcgal_upgrade_minor.sql
- mkdir -p sql
cat $^ > $@
-sql/$(EXTENSION)--$(EXTVERSION)next--$(EXTVERSION).sql: sql/$(EXTENSION)--$(EXTVERSION)--$(EXTVERSION)next.sql
- mkdir -p sql
- cp $< $@
sql_bits/sfcgal.sql: ../../postgis/sfcgal.sql
mkdir -p sql_bits
diff --git a/extensions/postgis_topology/Makefile.in b/extensions/postgis_topology/Makefile.in
index 13de422..0f3a2e6 100644
--- a/extensions/postgis_topology/Makefile.in
+++ b/extensions/postgis_topology/Makefile.in
@@ -5,6 +5,12 @@ EXTVERSION = @POSTGIS_LIB_VERSION@
MINORVERSION = @POSTGIS_MAJOR_VERSION at .@POSTGIS_MINOR_VERSION@
MODULEPATH = $$libdir/$(EXTENSION)- at POSTGIS_MAJOR_VERSION@
+ extlock.sql \
+ sql_bits/mark_editable_objects.sql.in \
+ sql_bits/topology_comments.sql \
+ sql_bits/topology.sql
ifeq (@LIBINCLUDEMINORVERSION@,yes)
MODULEPATH=$$libdir/$(EXTENSION)-$(MINORVERSION)
endif
@@ -54,10 +60,8 @@ $(EXTENSION).control: $(EXTENSION).control.in Makefile
sql:
mkdir -p $@
- cp $< $@
-sql/$(EXTENSION).sql: extlock.sql sql_bits/topology.sql sql_bits/mark_editable_objects.sql.in sql_bits/topology_comments.sql | sql
cat $^ > $@
#strip BEGIN/COMMIT since these are not allowed in extensions
Summary of changes:
extensions/postgis/Makefile.in | 11 ++++-------
extensions/postgis_raster/Makefile.in | 11 ++++-------
extensions/postgis_sfcgal/Makefile.in | 21 +++++++--------------
extensions/postgis_topology/Makefile.in | 12 ++++++++----
4 files changed, 23 insertions(+), 32 deletions(-)
hooks/post-receive
