[postgis-tickets] [PostGIS] #4650: Can't install postgis_sfcgal
PostGIS trac at osgeo.org
Fri Feb 28 20:58:17 PST 2020
 Reporter:  robe                   |      Owner:  strk
     Type:  defect                 |     Status:  assigned
 Priority:  blocker                |  Milestone:  PostGIS 3.1.0
Component:  build/upgrade/install  |    Version:  master
 Keywords:                         |
 I'm rerunning again to make sure its not a PG 13 issue.
 But debbie started failing after commit
 [9ed7d8436/git]
     Further simplification and unification of extension Makefiles
 (details)
 Commit 9ed7d8436b902f6086b54e753006bd14a87aba4d by Sandro Santilli
 The file was modified   extensions/postgis_topology/Makefile.in
 The file was modified   extensions/postgis/Makefile.in
 The file was modified   extensions/postgis_raster/Makefile.in
 The file was modified   extensions/postgis_sfcgal/Makefile.in
 Error she's showing is:
 18:12:02 Checking for shp2pgsql ... found
 18:12:02 Checking for pgsql2shp ... found
 18:12:02 TMPDIR is /var/lib/jenkins/workspace/postgis/tmp/3_1_pg13w64
 18:12:02 Creating database 'postgis_reg'
 18:12:04 Preparing db 'postgis_reg' using: CREATE EXTENSION postgis SCHEMA
 public
 18:12:06 Preparing db 'postgis_reg' using: CREATE EXTENSION postgis_sfcgal
 SCHEMA public
 18:12:06 Died at ../run_test.pl line 1462.
 18:12:06  failed (Error encountered creating EXTENSION POSTGIS_SFCGAL:
 /var/lib/jenkins/workspace/postgis/tmp/3_1_pg13w64/regress_log)
 18:12:06
 18:12:06 NOTICE:  schema "public" already exists, skipping
 18:12:06 CREATE SCHEMA
 18:12:06 CREATE EXTENSION
 18:12:06 ERROR:  function postgis_sfcgal_version() does not exist
 18:12:06
 18:12:06 make[2]: *** [Makefile:39: check] Error 1
 18:12:06 make[2]: Leaving directory
 '/var/lib/jenkins/workspace/postgis/branches/3.1/regress/sfcgal'
 18:12:06 make[1]: *** [Makefile:48: check-regress] Error 2
 18:12:06 make[1]: Leaving directory
 '/var/lib/jenkins/workspace/postgis/branches/3.1/regress'
 18:12:06 make: *** [GNUmakefile:20: check-regress] Error 1
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4650>
