[postgis-tickets] [SCM] PostGIS branch stable-3.0 updated. 41475b02d27ab752cd03d95a5dbc33df6dcccbed
Thu Jan 2 11:19:36 PST 2020
the project "PostGIS".
The branch, stable-3.0 has been updated
       via  41475b02d27ab752cd03d95a5dbc33df6dcccbed (commit)
       via  e4e436b3443c5e303d84e7d22c0fda96a14b458d (commit)
      from  f1795b5404e67630056e05697b9a6eb2ebb94290 (commit)
revisions in full, below.
commit 41475b02d27ab752cd03d95a5dbc33df6dcccbed
Author: Regina Obe <lr at pcorp.us>
Date:   Thu Jan 2 14:19:31 2020 -0500
    Fix missing quote nation_script. References #4596 for PostGIS 3.0.1
diff --git a/NEWS b/NEWS
index 9100c3d..18bae40 100644
--- a/NEWS
+++ b/NEWS
@@ -11,6 +11,8 @@ XXXX/XX/XX
   - #4606, Respect user's LDFLAGS in postgis module build (Sandro Santilli)
   - #4610, Add in logic to install postgis_tiger_geocoder from unpackaged (Regina obe)
   - #4581, installing postgis_raster from unpackaged tries to use wrong schema
+  - #4596, The script to generate nation_script_load.sh is missing
+           a trailing quote (Bill Mill)
 PostGIS 3.0.0
 2019/10/20
commit e4e436b3443c5e303d84e7d22c0fda96a14b458d
Author: Bill Mill <bill at billmill.org>
Date:   Thu Jan 2 11:39:14 2020 -0500
    add trailing quotes to malformed statements
diff --git a/extras/tiger_geocoder/tiger_loader_2017.sql b/extras/tiger_geocoder/tiger_loader_2017.sql
index 99427e9..9a7c6a7 100644
--- a/extras/tiger_geocoder/tiger_loader_2017.sql
+++ b/extras/tiger_geocoder/tiger_loader_2017.sql
@@ -312,7 +312,7 @@ ${psql} -c "CREATE INDEX idx_${data_schema}_${state_abbrev}_${lookup_name}_count
 INSERT INTO loader_lookuptables(process_order, lookup_name, table_name, load, level_county, level_state, level_nation, single_geom_mode, insert_mode, pre_load_process, post_load_process, columns_exclude )
 VALUES(13, 'zcta5_raw', 'zcta510', false,false, false,true, false, 'c',
 	'${psql} -c "CREATE TABLE ${data_schema}.${lookup_name}( zcta5 character varying(5), classfp character varying(2),mtfcc character varying(5), funcstat character varying(1), aland double precision, awater double precision, intptlat character varying(11), intptlon character varying(12), the_geom geometry(MultiPolygon,4269) );"',
-$post_load$${psql} -c "ALTER TABLE tiger.zcta5 DROP CONSTRAINT IF EXISTS enforce_geotype_the_geom; CREATE TABLE ${data_schema}.zcta5_all(CONSTRAINT pk_zcta5_all PRIMARY KEY (zcta5ce,statefp), CONSTRAINT uidx_${lookup_name}_all_gid UNIQUE (gid)) INHERITS(tiger.zcta5);
+$post_load$${psql} -c "ALTER TABLE tiger.zcta5 DROP CONSTRAINT IF EXISTS enforce_geotype_the_geom; CREATE TABLE ${data_schema}.zcta5_all(CONSTRAINT pk_zcta5_all PRIMARY KEY (zcta5ce,statefp), CONSTRAINT uidx_${lookup_name}_all_gid UNIQUE (gid)) INHERITS(tiger.zcta5);"
 ${psql} -c "SELECT loader_load_staged_data(lower('${table_name}'), lower('${lookup_name}'));"
 ${psql} -c "INSERT INTO ${data_schema}.zcta5_all(statefp, zcta5ce, classfp, mtfcc, funcstat, aland, awater, intptlat, intptlon, partflg, the_geom) SELECT  s.statefp, z.zcta5,  z.classfp, z.mtfcc, z.funcstat, z.aland, z.awater, z.intptlat, z.intptlon, CASE WHEN ST_Covers(s.the_geom, z.the_geom) THEN 'N' ELSE 'Y' END, ST_SnapToGrid(ST_Transform(CASE WHEN ST_Covers(s.the_geom, z.the_geom) THEN ST_SimplifyPreserveTopology(ST_Transform(z.the_geom,2163),1000) ELSE ST_SimplifyPreserveTopology(ST_Intersection(ST_Transform(s.the_geom,2163), ST_Transform(z.the_geom,2163)),1000)  END,4269), 0.000001) As geom FROM ${data_schema}.zcta5_raw AS z INNER JOIN tiger.state AS s ON (ST_Covers(s.the_geom, z.the_geom) or ST_Overlaps(s.the_geom, z.the_geom) );"
 	${psql} -c "DROP TABLE ${data_schema}.zcta5_raw; CREATE INDEX idx_${data_schema}_zcta5_all_the_geom_gist ON ${data_schema}.zcta5_all USING gist(the_geom);"$post_load$
diff --git a/extras/tiger_geocoder/tiger_loader_2018.sql b/extras/tiger_geocoder/tiger_loader_2018.sql
index 6c4005d..61e6879 100644
--- a/extras/tiger_geocoder/tiger_loader_2018.sql
+++ b/extras/tiger_geocoder/tiger_loader_2018.sql
diff --git a/extras/tiger_geocoder/tiger_loader_2019.sql b/extras/tiger_geocoder/tiger_loader_2019.sql
index bc4d51b..12a395b 100644
--- a/extras/tiger_geocoder/tiger_loader_2019.sql
+++ b/extras/tiger_geocoder/tiger_loader_2019.sql
Summary of changes:
 NEWS                                        | 2 ++
 extras/tiger_geocoder/tiger_loader_2017.sql | 2 +-
 extras/tiger_geocoder/tiger_loader_2018.sql | 2 +-
 extras/tiger_geocoder/tiger_loader_2019.sql | 2 +-
 4 files changed, 5 insertions(+), 3 deletions(-)
hooks/post-receive
