[postgis-tickets] [PostGIS] #4543: Use Ryū to output floating point numbers
trac at osgeo.org
Fri Jan 10 07:29:15 PST 2020
Reporter: Algunenano | Owner: Algunenano
Type: enhancement | Status: closed
Priority: medium | Milestone: PostGIS 3.1.0
Component: liblwgeom | Version: master
Resolution: fixed | Keywords:
Changes (by Raúl Marín <git@…>):
* status: assigned => closed
* resolution: => fixed
Comment:
In [changeset:"04f93f166054550bec87bc14ad435b42228b287e/git" 04f93f1/git]:
#!CommitTicketReference repository="git"
revision="04f93f166054550bec87bc14ad435b42228b287e"
Introduce ryu to print doubles
This massively (x10) speeds up lwprint_double and will be followed up
by improvements to improve other output functions that rely on it.
There has been some complications in adapting the function itself since
the output used by Postgis is by no means standard, choosing the number
of decimal digits based on the integer digits, user input and size
of the input buffer (although it should always be big enough)
Closes #4543
Closes https://github.com/postgis/postgis/pull/523
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4543#comment:5>
