[postgis-tickets] [SCM] PostGIS branch master updated. 3c069bf7d1d11625d810da07a635a8010718d99d
git at osgeo.org
git at osgeo.org
Wed Jan 15 02:47:06 PST 2020
the project "PostGIS".
via 3c069bf7d1d11625d810da07a635a8010718d99d (commit)
from 79e999360209cbe4a98ad26f39819fd1440db4f8 (commit)
revisions in full, below.
commit 3c069bf7d1d11625d810da07a635a8010718d99d
Author: Raúl Marín <git at rmr.ninja>
Date: Tue Jan 14 19:20:56 2020 +0100
Reduce output precision in ST_TileEnvelope test
The output is slightly different in 32bit plaftorms
Closes #4619
Closes https://github.com/postgis/postgis/pull/534
diff --git a/regress/core/regress.sql b/regress/core/regress.sql
index 6f5eea3..64c5042 100644
--- a/regress/core/regress.sql
+++ b/regress/core/regress.sql
@@ -268,7 +268,7 @@ select '226', ST_SRID(ST_Expand('SRID=4326;POINT (0 0)'::geometry, 1))=4326;
select '227', ST_AsEWKT(ST_TileEnvelope(-1, 0, 0));
select '228', ST_AsEWKT(ST_TileEnvelope(0, 0, 1));
select '229', ST_AsEWKT(ST_TileEnvelope(0, 0, 0));
-select '230', ST_AsEWKT(ST_TileEnvelope(4, 8, 8));
+select '230', ST_AsText(ST_TileEnvelope(4, 8, 8), 7);
select '231', ST_AsEWKT(ST_TileEnvelope(4, 15, 15));
select '232', ST_AsEWKT(ST_TileEnvelope(4, 8, 8, ST_MakeEnvelope(-100, -100, 100, 100, 0)));
select '233', ST_AsEWKT(ST_TileEnvelope(4, 15, 15, ST_MakeEnvelope(-100, -100, 100, 100, 0)));
diff --git a/regress/core/regress_expected b/regress/core/regress_expected
index f07b639..8577897 100644
--- a/regress/core/regress_expected
+++ b/regress/core/regress_expected
@@ -197,7 +197,7 @@ ERROR: geometry contains non-closed rings
ERROR: ST_TileEnvelope: Invalid tile zoom value, -1
ERROR: ST_TileEnvelope: Invalid tile y value, 1
229|SRID=3857;POLYGON((-20037508.342789 -20037508.342789,-20037508.342789 20037508.342789,20037508.342789 20037508.342789,20037508.342789 -20037508.342789,-20037508.342789 -20037508.342789))
-230|SRID=3857;POLYGON((0 -2504688.54284862,0 0,2504688.54284862 0,2504688.54284862 -2504688.54284862,0 -2504688.54284862))
+230|POLYGON((0 -2504688.5428486,0 0,2504688.5428486 0,2504688.5428486 -2504688.5428486,0 -2504688.5428486))
231|SRID=3857;POLYGON((17532819.7999404 -20037508.342789,17532819.7999404 -17532819.7999404,20037508.342789 -17532819.7999404,20037508.342789 -20037508.342789,17532819.7999404 -20037508.342789))
232|POLYGON((0 -12.5,0 0,12.5 0,12.5 -12.5,0 -12.5))
233|POLYGON((87.5 -100,87.5 -87.5,100 -87.5,100 -100,87.5 -100))
Summary of changes:
regress/core/regress.sql | 2 +-
regress/core/regress_expected | 2 +-
2 files changed, 2 insertions(+), 2 deletions(-)
hooks/post-receive
