[postgis-tickets] [SCM] PostGIS branch master updated. 69865c307e1de61a5ab9332e78d708e8a4169b5d
git at osgeo.org
git at osgeo.org
Wed Jan 15 11:01:33 PST 2020
the project "PostGIS".
via 69865c307e1de61a5ab9332e78d708e8a4169b5d (commit)
from f023465e0fed5afb7690f4cbeb576631995fb5a6 (commit)
revisions in full, below.
commit 69865c307e1de61a5ab9332e78d708e8a4169b5d
Author: Regina Obe <lr at pcorp.us>
Date: Wed Jan 15 14:01:27 2020 -0500
Minor code formatting so doesn't have weird break lines in programlisting
diff --git a/doc/installation.xml b/doc/installation.xml
index 1bd8a74..6efa4f9 100644
--- a/doc/installation.xml
+++ b/doc/installation.xml
@@ -1908,46 +1908,41 @@ environment).</para></note>
not using extensions. If you have extensions and try to
upgrade with this approach you'll get messages like:</para>
- <programlisting>can't drop ... because postgis extension depends on it</programlisting>
+ <programlisting>can't drop ... because postgis extension depends on it</programlisting>
- <para>
- NOTE: if you are moving from PostGIS 1.* to PostGIS 2.* or from
+ <para>NOTE: if you are moving from PostGIS 1.* to PostGIS 2.* or from
PostGIS 2.* prior to r7409, you cannot use this procedure but
- would rather need to do a
+ would rather need to do a
<link linkend="hard_upgrade">HARD UPGRADE</link>.
- </para>
+ </para>
- <para>
- After compiling and installing (make install) you should
- find a set of <filename>*_upgrade.sql</filename>
- files in the installation folders. You can list
- them all with:
- </para>
+ <para>
+ After compiling and installing (make install) you should
+ find a set of <filename>*_upgrade.sql</filename>
+ files in the installation folders. You can list
+ them all with:
+ </para>
- <programlisting>
- ls `pg_config --sharedir`/contrib/postgis-&last_release_version;/*_upgrade.sql
- </programlisting>
+ <programlisting>ls `pg_config --sharedir`/contrib/postgis-&last_release_version;/*_upgrade.sql</programlisting>
<para>
- Load them all in turn, starting from <filename>postgis_upgrade.sql</filename>.
- </para>
+ Load them all in turn, starting from <filename>postgis_upgrade.sql</filename>.
+ </para>
- <programlisting>
- psql -f postgis_upgrade.sql -d your_spatial_database
- </programlisting>
+ <programlisting>psql -f postgis_upgrade.sql -d your_spatial_database</programlisting>
- <para>
- The same procedure applies to raster,
- topology and sfcgal extensions, with upgrade files named
- <filename>rtpostgis_upgrade.sql</filename>,
- <filename>topology_upgrade.sql</filename> and
- <filename>sfcgal_upgrade.sql</filename> respectively.
- If you need them:
- </para>
+ <para>
+ The same procedure applies to raster,
+ topology and sfcgal extensions, with upgrade files named
+ <filename>rtpostgis_upgrade.sql</filename>,
+ <filename>topology_upgrade.sql</filename> and
+ <filename>sfcgal_upgrade.sql</filename> respectively.
+ If you need them:
+ </para>
- <programlisting>psql -f rtpostgis_upgrade.sql -d your_spatial_database</programlisting>
- <programlisting>psql -f topology_upgrade.sql -d your_spatial_database</programlisting>
- <programlisting>psql -f sfcgal_upgrade.sql -d your_spatial_database</programlisting>
+ <programlisting>psql -f rtpostgis_upgrade.sql -d your_spatial_database</programlisting>
+ <programlisting>psql -f topology_upgrade.sql -d your_spatial_database</programlisting>
+ <programlisting>psql -f sfcgal_upgrade.sql -d your_spatial_database</programlisting>
<note>
<para>
Summary of changes:
doc/installation.xml | 55 ++++++++++++++++++++++++----------------------------
1 file changed, 25 insertions(+), 30 deletions(-)
hooks/post-receive
