[postgis-tickets] [PostGIS] #4629: Remove NUMERICFLAGS
trac at osgeo.org
Wed Jan 29 04:24:46 PST 2020
Reporter: Algunenano | Owner: Algunenano
Type: enhancement | Status: assigned
Priority: medium | Milestone: PostGIS 3.1.0
Component: postgis | Version: master
Keywords: |
While looking at other flags, I noticed the existence of `NUMERICFLAGS`
which activates `-ffloat-store` if available.
I have 2 issues with this:
* It's only used in some parts (liblwgeom/ and libpgcommon/), while other
folders know nothing about it.
* It's bad for precision (you voluntarily accept less precision) and, I
guess, performance since you are not using the registers.
As of today, I get the same results for clang (without that option) and
with GCC (which has that flag available), so I suggest dropping it
altogether and in the case that we find some difference in an output, try
to change it to allow both 80bit and 64bit precision in double operations.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4629>
