[postgis-tickets] [SCM] PostGIS branch master updated. 220be347eeb5dea6a4a46f871e87779249353038
Thu Jan 30 05:04:10 PST 2020
the project "PostGIS".
       via  220be347eeb5dea6a4a46f871e87779249353038 (commit)
      from  2a9e136e0b65d7f8ec194c1ec5479d595c340564 (commit)
revisions in full, below.
commit 220be347eeb5dea6a4a46f871e87779249353038
Author: Raúl Marín <git at rmr.ninja>
Date:   Wed Jan 29 13:33:57 2020 +0100
    Enforce local folders to be included first
    References #4626
diff --git a/deps/Makefile.in b/deps/Makefile.in
index 4262f96..14fea56 100644
--- a/deps/Makefile.in
+++ b/deps/Makefile.in
@@ -24,8 +24,8 @@
 CC=@CC@
 CXX=@CXX@
-CFLAGS=-I../liblwgeom @WARNFLAGS@ @CFLAGS@ @PICFLAGS@
-CXXFLAGS=-I../liblwgeom @WARNFLAGS@ @CXXFLAGS@ @PICFLAGS@
+CFLAGS=-I../liblwgeom @CPPFLAGS@ @WARNFLAGS@ @CFLAGS@ @PICFLAGS@
+CXXFLAGS=-I../liblwgeom @CPPFLAGS@ @WARNFLAGS@ @CXXFLAGS@ @PICFLAGS@
 LDFLAGS = @LDFLAGS@
 top_builddir = @top_builddir@
 libdir = @libdir@
diff --git a/doc/html/image_src/Makefile.in b/doc/html/image_src/Makefile.in
index 9fb00a2..43eccf6 100644
--- a/doc/html/image_src/Makefile.in
+++ b/doc/html/image_src/Makefile.in
@@ -175,7 +175,7 @@ images: $(IMAGES) $(IMAGES_RESIZED)
 # Command to build each of the .o files
 $(OBJS): %.o: %.c
-	$(CC) $(CFLAGS) $(CUNIT_CPPFLAGS) -c -o $@ $<
+	$(CC) $(CUNIT_CPPFLAGS) $(CFLAGS) -c -o $@ $<
 # Command to build each of the .wkt files
 $(IMAGES): ../images/%.png: %.wkt generator styles.conf
diff --git a/liblwgeom/cunit/Makefile.in b/liblwgeom/cunit/Makefile.in
index 008821b..3fe9942 100644
--- a/liblwgeom/cunit/Makefile.in
+++ b/liblwgeom/cunit/Makefile.in
@@ -15,7 +15,7 @@ SHELL = @SHELL@
 LIBTOOL = @LIBTOOL@
 CUNIT_LDFLAGS=@CUNIT_LDFLAGS@
-CUNIT_CPPFLAGS=@CUNIT_CPPFLAGS@ -I.. @CPPFLAGS@
+CUNIT_CPPFLAGS=-I.. @CUNIT_CPPFLAGS@ @CPPFLAGS@
 CFLAGS=$(CUNIT_CPPFLAGS) @WARNFLAGS@ @CFLAGS@
 LDFLAGS = @GEOS_LDFLAGS@ $(CUNIT_LDFLAGS)
diff --git a/libpgcommon/Makefile.in b/libpgcommon/Makefile.in
index 39fffa0..006bab1 100644
--- a/libpgcommon/Makefile.in
+++ b/libpgcommon/Makefile.in
@@ -62,7 +62,7 @@ check-unit: libpgcommon.a
 $(SA_OBJS): %.o: %.c
-	$(CC) $(CPPFLAGS) $(CFLAGS) -c -o $@ $<
+	$(CC) $(CFLAGS) -c -o $@ $<
 $(SA_OBJS): ../postgis_config.h
diff --git a/loader/cunit/Makefile.in b/loader/cunit/Makefile.in
index 5c5e983..9e50020 100644
--- a/loader/cunit/Makefile.in
+++ b/loader/cunit/Makefile.in
@@ -16,7 +16,7 @@ SHELL = @SHELL@
 LIBTOOL = @LIBTOOL@
 # GTK includes and libraries
 GTK_CFLAGS = @GTK_CFLAGS@ @IGE_MAC_CFLAGS@
diff --git a/raster/test/cunit/Makefile.in b/raster/test/cunit/Makefile.in
index fead5c6..98724ce 100644
--- a/raster/test/cunit/Makefile.in
+++ b/raster/test/cunit/Makefile.in
@@ -45,7 +45,7 @@ LDFLAGS = \
 	$(PROJ_LDFLAGS)
-CUNIT_CPPFLAGS=@CUNIT_CPPFLAGS@ @CPPFLAGS@ -I..
 # ADD YOUR NEW TEST FILE HERE (1/1)
 OBJS=	\
@@ -84,7 +84,7 @@ cu_tester: $(RT_CORE)/librtcore.a $(OBJS)
 $(OBJS): %.o: %.c
 $(RT_CORE)/librtcore.a:
 	$(MAKE) -C ../../rt_core
diff --git a/topology/Makefile.in b/topology/Makefile.in
index e86fcf1..68ea0bd 100644
--- a/topology/Makefile.in
+++ b/topology/Makefile.in
@@ -51,7 +51,7 @@ OBJS = postgis_topology.o
 # to an existing liblwgeom.so in the PostgreSQL $libdir supplied by an
 # older version of PostGIS, rather than with the static liblwgeom.a
 # supplied with newer versions of PostGIS
-PG_CPPFLAGS += -I../liblwgeom @CFLAGS@ -I../libpgcommon @CPPFLAGS@ @PICFLAGS@
+PG_CPPFLAGS += -I../liblwgeom -I../libpgcommon @CFLAGS@ @CPPFLAGS@ @PICFLAGS@
 SHLIB_LINK_F = ../libpgcommon/libpgcommon.a ../liblwgeom/.libs/liblwgeom.a @SHLIB_LINK@
 # Add SFCGAL Flags if defined
Summary of changes:
 deps/Makefile.in               | 4 ++--
 doc/html/image_src/Makefile.in | 2 +-
 liblwgeom/cunit/Makefile.in    | 2 +-
 libpgcommon/Makefile.in        | 2 +-
 loader/cunit/Makefile.in       | 2 +-
 raster/test/cunit/Makefile.in  | 4 ++--
 topology/Makefile.in           | 2 +-
 7 files changed, 9 insertions(+), 9 deletions(-)
hooks/post-receive
