[postgis-tickets] [PostGIS] #4626: Fails to build with libxml2 2.9.10 (uses xml2-config)
trac at osgeo.org
Thu Jan 30 15:36:17 PST 2020
Reporter: Bas Couwenberg | Owner: pramsey
Type: defect | Status: reopened
Priority: medium | Milestone: PostGIS 2.5.4
Component: postgis | Version: 2.5.x
Resolution: | Keywords:
Comment (by robe):
FYI the bessie build failing on raster, might have been some loose
liblwgeom flaoting.
I found liblwgeom installed in /usr/local/include liblwgeom.h
and liblwgeom_topo.h
Also found in /usr/local/lib liblwgeom-2.4.so.0, liblwgeom-2.5.so ..,
liblwgeom.so
I deleted the non-versioned ones from here and the include files and reran
and then bessie was fine. So I think it still might be picking up non-
local first.
before:
https://debbie.postgis.net/view/PostGIS/job/PostGIS_Worker_Run/label=bessie/1875/consoleFull
10:27:28 Test: test_raster_envelope_geom ...gmake[4]: *** [Makefile:77:
check] Segmentation fault (core dumped)
10:27:28 gmake[4]: Leaving directory
'/usr/home/jenkins/workspace/PostGIS_Worker_Run/label/bessie/220be347eeb5dea6a4a46f871e87779249353038/raster/test/cunit'
after:
https://debbie.postgis.net/view/PostGIS/job/PostGIS_Worker_Run/label=bessie/1876/console
all tests pass
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4626#comment:15>
