[postgis-tickets] [SCM] PostGIS branch master updated. cdd520d378efb2d6b0b3ced7de566107a2a5b4a2
git at osgeo.org
git at osgeo.org
Fri Jan 31 08:51:18 PST 2020
the project "PostGIS".
via cdd520d378efb2d6b0b3ced7de566107a2a5b4a2 (commit)
via 92fc725d54e67326eb53e713b7aa8775ed9c9cd0 (commit)
from 3a1e232811879b9ded3bca257f56fc12ad04f856 (commit)
revisions in full, below.
commit cdd520d378efb2d6b0b3ced7de566107a2a5b4a2
Author: Raúl Marín <git at rmr.ninja>
Date: Fri Jan 31 17:39:58 2020 +0100
Remove WARNFLAGS
Closes #4630
diff --git a/configure.ac b/configure.ac
index 057e914..9961dd2 100644
--- a/configure.ac
+++ b/configure.ac
@@ -65,15 +65,6 @@ AC_LIBTOOL_COMPILER_OPTION([if $compiler supports -std=gnu99], [_cv_std], -std=g
dnl
-dnl For GCC enable additional warning flags -Wall and -Wmissing-prototypes (using macro included with libtool)
-dnl
-WARNFLAGS=""
-AC_LIBTOOL_COMPILER_OPTION([if $compiler supports -Wall], [_cv_wall], [-Wall], [], [WARNFLAGS="$WARNFLAGS -Wall"], [])
-AC_LIBTOOL_COMPILER_OPTION([if $compiler supports -Wmissing-prototypes], [_cv_misprot], [-Wmissing-prototypes], [], [WARNFLAGS="$WARNFLAGS -Wmissing-prototypes"], [])
-AC_SUBST([WARNFLAGS])
-dnl
dnl Add libm to LDFLAGS so we don't need to add it everywhere manually
dnl
LDFLAGS="$LDFLAGS -lm"
diff --git a/deps/Makefile.in b/deps/Makefile.in
index 14fea56..04a1fc8 100644
--- a/deps/Makefile.in
+++ b/deps/Makefile.in
@@ -24,8 +24,8 @@
CC=@CC@
CXX=@CXX@
-CFLAGS=-I../liblwgeom @CPPFLAGS@ @WARNFLAGS@ @CFLAGS@ @PICFLAGS@
-CXXFLAGS=-I../liblwgeom @CPPFLAGS@ @WARNFLAGS@ @CXXFLAGS@ @PICFLAGS@
+CFLAGS=-I../liblwgeom @CPPFLAGS@ @CFLAGS@ @PICFLAGS@
+CXXFLAGS=-I../liblwgeom @CPPFLAGS@ @CXXFLAGS@ @PICFLAGS@
LDFLAGS = @LDFLAGS@
top_builddir = @top_builddir@
libdir = @libdir@
diff --git a/doc/html/image_src/Makefile.in b/doc/html/image_src/Makefile.in
index 43eccf6..5cf5079 100644
--- a/doc/html/image_src/Makefile.in
+++ b/doc/html/image_src/Makefile.in
@@ -10,7 +10,7 @@
CC=@CC@
-CFLAGS=@WARNFLAGS@ @CFLAGS@ @PROJ_CPPFLAGS@
+CFLAGS=@CFLAGS@ @PROJ_CPPFLAGS@
SHELL = @SHELL@
LIBTOOL = @LIBTOOL@
diff --git a/liblwgeom/Makefile.in b/liblwgeom/Makefile.in
index 9496c6b..679cf9d 100644
--- a/liblwgeom/Makefile.in
+++ b/liblwgeom/Makefile.in
@@ -25,7 +25,7 @@
CC = @CC@
RYU_INCLUDE = -I../deps/ryu/..
CPPFLAGS = $(RYU_INCLUDE) @CPPFLAGS@
-CFLAGS = @WARNFLAGS@ @CFLAGS@ @PICFLAGS@
+CFLAGS = @CFLAGS@ @PICFLAGS@
LDFLAGS = @LDFLAGS@ @GEOS_LDFLAGS@ @PROJ_LDFLAGS@ @JSON_LDFLAGS@
prefix = @prefix@
diff --git a/liblwgeom/cunit/Makefile.in b/liblwgeom/cunit/Makefile.in
index 3fe9942..be2dd97 100644
--- a/liblwgeom/cunit/Makefile.in
+++ b/liblwgeom/cunit/Makefile.in
@@ -16,7 +16,7 @@ LIBTOOL = @LIBTOOL@
CUNIT_LDFLAGS=@CUNIT_LDFLAGS@
CUNIT_CPPFLAGS=-I.. @CUNIT_CPPFLAGS@ @CPPFLAGS@
-CFLAGS=$(CUNIT_CPPFLAGS) @WARNFLAGS@ @CFLAGS@
+CFLAGS=$(CUNIT_CPPFLAGS) @CFLAGS@
LDFLAGS = @GEOS_LDFLAGS@ $(CUNIT_LDFLAGS)
ifeq ($(CUNIT_WITH_VALGRIND), YES)
diff --git a/libpgcommon/Makefile.in b/libpgcommon/Makefile.in
index 006bab1..05ce1c0 100644
--- a/libpgcommon/Makefile.in
+++ b/libpgcommon/Makefile.in
@@ -10,11 +10,9 @@
CC=@CC@
-CFLAGS= -I../liblwgeom @CPPFLAGS@ @WARNFLAGS@ @CFLAGS@ @PGSQL_BE_CPPFLAGS@ @PROJ_CPPFLAGS@ @PICFLAGS@ @GETTEXT_CFLAGS@
+CFLAGS= -I../liblwgeom @CPPFLAGS@ @CFLAGS@ @PGSQL_BE_CPPFLAGS@ @PROJ_CPPFLAGS@ @PICFLAGS@ @GETTEXT_CFLAGS@
LDFLAGS=@GETTEXT_LDFLAGS@ @LIBINTL@
-NUMERICFLAGS=@NUMERICFLAGS@
YACC=@YACC@
LEX=@LEX@
diff --git a/loader/Makefile.in b/loader/Makefile.in
index 40b1c17..e6d1af0 100644
--- a/loader/Makefile.in
+++ b/loader/Makefile.in
@@ -22,7 +22,7 @@ include $(PGXS)
# Set CFLAGS afer PGXS, otherwise it will get overwritten with the PGXS
# version which is not what we want.
CC=@CC@
-CFLAGS= -I ../liblwgeom @CPPFLAGS@ @WARNFLAGS@ @CFLAGS@ @PICFLAGS@ @PROJ_CPPFLAGS@
+CFLAGS= -I ../liblwgeom @CPPFLAGS@ @CFLAGS@ @PICFLAGS@ @PROJ_CPPFLAGS@
SHELL = @SHELL@
INSTALL = @INSTALL@
diff --git a/loader/cunit/Makefile.in b/loader/cunit/Makefile.in
index 1fcf884..429fa85 100644
--- a/loader/cunit/Makefile.in
+++ b/loader/cunit/Makefile.in
@@ -11,7 +11,7 @@
CC=@CC@
+CFLAGS=@CFLAGS@
SHELL = @SHELL@
LIBTOOL = @LIBTOOL@
diff --git a/raster/Makefile.in b/raster/Makefile.in
index 9b4cf8c..d8a12d0 100644
--- a/raster/Makefile.in
+++ b/raster/Makefile.in
@@ -20,7 +20,7 @@
CC=@CC@
-CFLAGS=-I../liblwgeom @WARNFLAGS@ @CFLAGS@
+CFLAGS=-I../liblwgeom @CFLAGS@
LDFLAGS = @LDFLAGS@
all: @RT_CORE_LIB@ @RT_PG_LIB@ @RT_LOADER@ @RT_POSTGIS_SQL@
diff --git a/raster/loader/Makefile.in b/raster/loader/Makefile.in
index fbbab3a..3df47a9 100644
--- a/raster/loader/Makefile.in
+++ b/raster/loader/Makefile.in
@@ -57,7 +57,7 @@ ICONV_LDFLAGS=@ICONV_LDFLAGS@
ICONV_CFLAGS=@ICONV_CFLAGS@
CFLAGS = \
- @WARNFLAGS@ @CFLAGS@ @PICFLAGS@ \
+ @CFLAGS@ @PICFLAGS@ \
$(RTCORE_CFLAGS) \
$(LIBLWGEOM_CFLAGS) \
$(PROJ_CFLAGS) \
diff --git a/raster/rt_core/Makefile.in b/raster/rt_core/Makefile.in
index fb96470..1730405 100644
--- a/raster/rt_core/Makefile.in
+++ b/raster/rt_core/Makefile.in
@@ -28,7 +28,7 @@ LIBGDAL_LDFLAGS = @LIBGDAL_LDFLAGS@
GEOS_LDFLAGS = @GEOS_LDFLAGS@
PROJ_LDFLAGS = @PROJ_LDFLAGS@
LDFLAGS = $(LIBLWGEOM_LDFLAGS) $(LIBGDAL_LDFLAGS) $(PROJ_LDFLAGS) $(GEOS_LDFLAGS)
-CFLAGS = $(LIBLWGEOM_CFLAGS) @CPPFLAGS@ @WARNFLAGS@ @CFLAGS@ @PICFLAGS@ $(LIBGDAL_CFLAGS) @PROJ_CPPFLAGS@ @GEOS_CPPFLAGS@
+CFLAGS = $(LIBLWGEOM_CFLAGS) @CPPFLAGS@ @CFLAGS@ @PICFLAGS@ $(LIBGDAL_CFLAGS) @PROJ_CPPFLAGS@ @GEOS_CPPFLAGS@
# Standalone RTCORE objects
RT_OBJS = \
diff --git a/raster/test/cunit/Makefile.in b/raster/test/cunit/Makefile.in
index 30b184d..f341e18 100644
--- a/raster/test/cunit/Makefile.in
+++ b/raster/test/cunit/Makefile.in
@@ -35,7 +35,7 @@ CFLAGS = \
$(PROJ_CFLAGS) \
$(LIBGDAL_CFLAGS) \
$(GEOS_CFLAGS) \
- @WARNFLAGS@ @CFLAGS@ \
+ @CFLAGS@ \
LDFLAGS = \
$(RTCORE_LDFLAGS) \
commit 92fc725d54e67326eb53e713b7aa8775ed9c9cd0
Date: Fri Jan 31 17:37:44 2020 +0100
Remove NUMERICFLAGS
Closes #4629
index 2ba040f..057e914 100644
--- a/configure.ac
+++ b/configure.ac
@@ -72,12 +72,6 @@ AC_LIBTOOL_COMPILER_OPTION([if $compiler supports -Wall], [_cv_wall], [-Wall], [
-dnl
-dnl For some GCC versions and platforms, floating point issues need to be
-dnl ironed out.
-NUMERICFLAGS=""
-AC_LIBTOOL_COMPILER_OPTION([if $compiler supports -ffloat-store], [dummy_cv_ffloat_store], [-ffloat-store], [], [NUMERICFLAGS="$NUMERICFLAGS -ffloat-store"], [])
-AC_SUBST([NUMERICFLAGS])
dnl
index 77fe5be..9496c6b 100644
@@ -27,7 +27,6 @@ RYU_INCLUDE = -I../deps/ryu/..
-NUMERICFLAGS = @NUMERICFLAGS@
prefix = @prefix@
exec_prefix = @exec_prefix@
@@ -211,7 +210,7 @@ $(LT_SA_OBJS): %.lo: %.c
$(LIBTOOL) --mode=compile $(CC) $(CPPFLAGS) $(CFLAGS) -c -o $@ $<
$(LT_NM_OBJS): %.lo: %.c
- $(LIBTOOL) --mode=compile $(CC) $(CPPFLAGS) $(CFLAGS) $(NUMERICFLAGS) -c -o $@ $<
+ $(LIBTOOL) --mode=compile $(CC) $(CPPFLAGS) $(CFLAGS) -c -o $@ $<
lwin_wkt_parse.c lwin_wkt_parse.h: lwin_wkt_parse.y
@test -n "$(YACC)" || { \
Summary of changes:
configure.ac | 15 ---------------
deps/Makefile.in | 4 ++--
doc/html/image_src/Makefile.in | 2 +-
liblwgeom/Makefile.in | 5 ++---
liblwgeom/cunit/Makefile.in | 2 +-
libpgcommon/Makefile.in | 4 +---
loader/Makefile.in | 2 +-
loader/cunit/Makefile.in | 2 +-
raster/Makefile.in | 2 +-
raster/loader/Makefile.in | 2 +-
raster/rt_core/Makefile.in | 2 +-
raster/test/cunit/Makefile.in | 2 +-
12 files changed, 13 insertions(+), 31 deletions(-)
hooks/post-receive
