[postgis-tickets] [PostGIS] #4700: Add more geography functions
PostGIS trac at osgeo.org
Mon Jun 8 02:19:15 PDT 2020
 Reporter:  vogg         |      Owner:  pramsey
     Type:  enhancement  |     Status:  new
 Priority:  medium       |  Milestone:
Component:  postgis      |    Version:  2.3.x
 Keywords:  geography    |
 When working with the GEOGRAPHY type, there are still many functions
 missing, compared to the GEOMETRY type. This makes working with GEOGRAPHY
 a lot more cumbersome than it needs to be.
 While it is clear that some functions require extra care, we should at
 least provide proper support for the "trivial" functions which are merely
 packing and unpacking data structures.
 In a real-world codebase, I found myself implementing the following helper
 functions. Those already go a long way, and motivated coworkers to use
 proper GEOGRAPHY where they otherwise would have avoided all that trouble:
 create or replace function ad_internal.ST_MakeLine(geog1 geography, geog2
 geography) returns geography immutable language sql as $$
   select ST_MakeLine(geog1::geometry, geog2::geometry)::geography
 create or replace function ad_internal.ST_StartPoint(line geography)
   select ST_StartPoint(line::geometry)::geography
 create or replace function ad_internal.ST_EndPoint(line geography) returns
   select ST_EndPoint(line::geometry)::geography
 create or replace function ad_internal.ST_Collect(g1 geography, g2
   select ST_Collect(g1::geometry, g2::geometry)::geography
 create or replace function ad_internal.ST_Points(geog geography) returns
   select ST_Points(geog::geometry)::geography
 In addition, I propose the following addition to ST_Azimuth(), which
 allows us to treat a 2-point-line as vector and calculating its azimuth
 (it may be open to debate whether this function should be restricted to
 1-point lines, or should allow for any line string, but taking the vector
 only from the first point directly to the last point):
 create or replace function ad_internal.ST_Azimuth(line geography) returns
 float immutable language sql as $$
   select ST_Azimuth(ad_internal.ST_StartPoint(line),
 ad_internal.ST_EndPoint(line))
 Note that all implementations are pure SQL. Is this okay, or are those
 functions are only acceptable when provided as low-level C/C++ functions?
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4700>
