[postgis-tickets] [PostGIS] #4702: Legacy ST_Locate_Between_Measures is wrong
trac at osgeo.org
Mon Jun 8 09:28:34 PDT 2020
Reporter: pramsey | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.0.2
Component: postgis | Version: 3.0.x
Keywords: |
diff --git a/postgis/legacy.sql.in b/postgis/legacy.sql.in
index 6a720dda0..d750541e8 100644
--- a/postgis/legacy.sql.in
+++ b/postgis/legacy.sql.in
@@ -2056,7 +2056,7 @@ CREATE OR REPLACE FUNCTION
ST_line_locate_point(geom1 geometry, geom2 geometry)
-- Deprecation in 2.0.0 replaced by ST_LocateBetween
CREATE OR REPLACE FUNCTION ST_locate_between_measures(geometry, float8,
float8)
RETURNS geometry AS
- 'SELECT ST_LocateBetween($1, $2, $2);'
+ 'SELECT ST_LocateBetween($1, $2, $3);'
LANGUAGE 'sql' IMMUTABLE STRICT;
-- Availability: 1.2.2
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4702>
