[postgis-tickets] [PostGIS] #4705: pgsql2shp - Pg field column in mapping file incorrectly compared with the name of the dbf field name
trac at osgeo.org
Tue Jun 16 07:36:50 PDT 2020
Reporter: zezzagio | Owner: robe
Type: defect | Status: new
Priority: medium | Milestone:
Component: loader/dumper | Version: 3.0.x
Resolution: | Keywords:
Comment (by strk):
Hi Zez, do you think you could also help with automating
a test to secure this bugfix ? The run_test.pl script does
have support for testing options passed to the loader&dumper
roundtrip and a test exists checking it (possibly not
exhaustive to include this case).
You can run the test with:
cd regress
make staged-install
cd loader
../run_test.pl -v mfile
The test will apply switches in mfile.opts which happens
to pass -m mfile_mapping.txt having the following mapping:
address add
short_name short
If I understand you correctly it would be enough to just
add a mapping with a different beginning ?
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4705#comment:2>
