[postgis-tickets] [PostGIS] #4705: pgsql2shp - Pg field column in mapping file incorrectly compared with the name of the dbf field name
PostGIS trac at osgeo.org
Fri Jun 19 08:42:10 PDT 2020
  Reporter:  zezzagio       |      Owner:  robe
      Type:  defect         |     Status:  new
  Priority:  medium         |  Milestone:
 Component:  loader/dumper  |    Version:  3.0.x
Resolution:                 |   Keywords:
Comment (by strk):
 Great that you learned git rebase.
 I can suggest you to also learn `git reset`,
 which keeps the changes but drops the commits,
 so you can re-do the commits to your liking.
 For exmaple you probably don't want one commit
 that adds the -pre and -post files and another
 that removes them :)
 The way I see it this could be 2 commits:
   1. Fix run_test.pl to do the {regdir} substitution
      and the continuation on install-objects mismatch
   2. Fix pgsql2shp handling of -m and associated tests
 Note: you can add "Closes #4705" in the commit log
 for commit 2 to see this ticket automatically closed
 upon acceptance of the changes.
 Let me know if you prefer leaving these things to
 us (but I recommend you learn to juggle with this
 great tool :)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4705#comment:16>
