[postgis-tickets] [SCM] PostGIS branch stable-2.5 updated. 2.5.4-17-g778d66b
git at osgeo.org
git at osgeo.org
Sat Jun 27 12:09:47 PDT 2020
the project "PostGIS".
The branch, stable-2.5 has been updated
via 778d66b336f613e1072ff53b2e206a51d344d706 (commit)
from 55c042d5f79a2f1db522718636f8f7d3c874565b (commit)
revisions in full, below.
commit 778d66b336f613e1072ff53b2e206a51d344d706
Author: Regina Obe <lr at pcorp.us>
Date: Sat Jun 27 15:09:42 2020 -0400
Add berrie64 and berrie to jenkins bot chain references #4708 for PostGIS 2.5
diff --git a/README.md b/README.md
index e3c056c..95dfcd4 100644
--- a/README.md
+++ b/README.md
@@ -9,6 +9,11 @@ Travis:
GitLab-CI:
[](https://gitlab.com/postgis/postgis/commits/stable-2.5)
+ Berrie:
+ [](https://debbie.postgis.net/view/PostGIS/job/PostGIS_Worker_Run/label=berrie/)
+ Berrie64:
+ [](https://debbie.postgis.net/view/PostGIS/job/PostGIS_Worker_Run/label=berrie64/)
This file is here to play nicely with modern code repository facilities.
Actual readme is [here](README.postgis).
diff --git a/ci/berrie/pg_init_start.sh b/ci/berrie/pg_init_start.sh
new file mode 100644
index 0000000..7914f0e
--- /dev/null
+++ b/ci/berrie/pg_init_start.sh
@@ -0,0 +1,36 @@
+#Berrie is a 32-bit Rasberry Pi Arm managed by Bruce Rindahl
+#This is script to launch custom compiled PostgreSQL
+#export label=berrie64 #this is passed in via Jenkins
+export WORKSPACE=/home/jenkins/workspace
+export OS_BUILD=32
+export PG_VER=12
+export PGPATH=${WORKSPACE}/pg/label/${label}/rel/pg${PG_VER}w${OS_BUILD}
+export PATH=${PATH}:${PGPATH}/bin:${PGPATH}/lib
+export PGPORT=55432
+export PGDATA=$PGPATH/data_${PGPORT}
+export PGLOG="$PGDATA/pgsql.log"
+# What to use to start up the postmaster
+DAEMON="$PGPATH/bin/pg_ctl -D $PGDATA -l logfile start"
+# What to use to shut down the postmaster
+PGCTL="$PGPATH/bin/pg_ctl"
+# remove cluster if exists
+if [ -d $PGDATA ] ; then
+ if [ -d $PGDATA/postmaster.pid] ; then
+ $PGCTL stop -D $PGDATA -s -m fast
+ fi;
+ rm -rf $PGDATA
+fi;
+#initialize cluster
+$PGPATH/bin/initdb
+echo -n "Starting PostgreSQL: "
+$DAEMON &
+#sleep a bit because sometimes postgres takes a bit to start up
+sleep 20
+echo "ok"
+exit 0
diff --git a/ci/berrie/postgis_regress.sh b/ci/berrie/postgis_regress.sh
index 0000000..0d1f0b9
--- /dev/null
+++ b/ci/berrie/postgis_regress.sh
@@ -0,0 +1,33 @@
+#!/bin/bash
+# Berrie is a 32-bit Rasberry Pi Arm managed by Bruce Rindahl
+## BRANCH is passed in via jenkins which is set via gitea web hook
+#export BRANCH=618a67b1d6fc223dd5a4c0b02c824939f21dbd65
+## label is set by jenkins
+#export label=${label}
+cd ${WORKSPACE}/PostGIS_Worker_Run/label/${label}/$BRANCH
+export OS_BUILD=32
+export PG_VER=12
+export PGHOST=localhost
+sh autogen.sh
+./configure --with-pgconfig=${PGPATH}/bin/pg_config
+#make clean
+make
+export err_status=0
+make check RUNTESTFLAGS="-v"
+make install
+make check RUNTESTFLAGS="-v --extension"
+err_status=$?
+if [ -d $PGDATA/postmaster.pid ] ; then
+fi
+exit $err_status
diff --git a/ci/berrie64/pg_init_start.sh b/ci/berrie64/pg_init_start.sh
index 0000000..0ebe243
--- /dev/null
+++ b/ci/berrie64/pg_init_start.sh
@@ -0,0 +1,36 @@
+#Berrie64 is a 64-bit Rasberry Pi Arm managed by Bruce Rindahl
+export OS_BUILD=64
+export PG_VER=12
+ fi;
+ rm -rf $PGDATA
+fi;
+$PGPATH/bin/initdb
+$DAEMON &
+sleep 20
+echo "ok"
+exit 0
diff --git a/ci/berrie64/postgis_regress.sh b/ci/berrie64/postgis_regress.sh
index 0000000..5bcebfb
--- /dev/null
+++ b/ci/berrie64/postgis_regress.sh
@@ -0,0 +1,33 @@
+#!/bin/bash
+# Berrie64 is a 64-bit Rasberry Pi Arm managed by Bruce Rindahl
+export OS_BUILD=64
+export PG_VER=12
+sh autogen.sh
+#make clean
+make
+make install
+err_status=$?
+fi
+exit $err_status
Summary of changes:
README.md | 5 +++++
ci/berrie/pg_init_start.sh | 36 ++++++++++++++++++++++++++++++++++++
ci/berrie/postgis_regress.sh | 33 +++++++++++++++++++++++++++++++++
ci/berrie64/pg_init_start.sh | 36 ++++++++++++++++++++++++++++++++++++
ci/berrie64/postgis_regress.sh | 33 +++++++++++++++++++++++++++++++++
5 files changed, 143 insertions(+)
create mode 100644 ci/berrie/pg_init_start.sh
create mode 100644 ci/berrie/postgis_regress.sh
create mode 100644 ci/berrie64/pg_init_start.sh
create mode 100644 ci/berrie64/postgis_regress.sh
hooks/post-receive
