[postgis-tickets] [PostGIS] #4711: ST_Union loses precision on complex multilinestring geometries
trac at osgeo.org
Tue Jun 30 08:22:24 PDT 2020
Reporter: dannytoone | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.1.0
Component: postgis | Version: 3.0.x
Resolution: | Keywords:
Comment (by pramsey):
It reproduces.
You've managed to produce a data set that has a lot of cases in it where
the line intersection routines produce numerical precision problems
(leading to the dreaded "TopologyException" error).
In an attempt to recover from TopologyExceptions, GEOS has fallback code
that tries to perturb the geometry in hopes of side-stepping the precision
issues. That code includes a routine that progressively strips precision
from the inputs. This is almost 100% for sure the problem. Amazingly, it
does eventually succeed in getting to an answer without an exception.
Unfortunately, that answer is garbage.
The alternative, unfortunately, would be turning off the fallbacks and
having the calculation simply stop when it hits the exception.
My colleague Martin Davis and I are working on bringing a more robust
algorithm for overlay (union/difference/intersection) from JTS into GEOS,
I'll point him to your data so he can ensure that the new algorithm does
in fact correctly handle it. If we are fortunate it will be in GEOS 3.9 in
the fall.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4711#comment:4>
