[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0alpha1-95-g3ced96f
Fri May 1 02:30:43 PDT 2020
the project "PostGIS".
       via  3ced96fc1a79831a26c33311a17d1f32e3c5c732 (commit)
      from  b28cfb9b923d2190877065fc6dd47a1a6bd961bb (commit)
revisions in full, below.
commit 3ced96fc1a79831a26c33311a17d1f32e3c5c732
Author: Raúl Marín <git at rmr.ninja>
Date:   Fri May 1 11:09:36 2020 +0200
    Internal cache now persists until the end of the transaction
    Closes #4674
diff --git a/NEWS b/NEWS
index e79c549..9758de6 100644
--- a/NEWS
+++ b/NEWS
@@ -4,7 +4,7 @@ PostGIS 3.1.0XXXX
 Only tickets not included in 3.1.0alpha1
 * Breaking changes *
+  - #4674, Internal cache now persists until the end of the transaction (Raúl Marín)
 * New features *
   - #4656, Cast a geojson_text::geometry for implicit GeoJSON ingestion (Raúl Marín)
diff --git a/libpgcommon/lwgeom_cache.c b/libpgcommon/lwgeom_cache.c
index b57e6f0..797fb66 100644
--- a/libpgcommon/lwgeom_cache.c
+++ b/libpgcommon/lwgeom_cache.c
@@ -11,7 +11,9 @@
 #include "postgres.h"
+#include "executor/spi.h"
 #include "fmgr.h"
+#include "utils/memutils.h"
 #include "../postgis_config.h"
@@ -56,13 +58,25 @@ typedef struct {
 } GenericCacheCollection;
-* Utility function to read the upper memory context off a function call
-* info data.
-static MemoryContext
-FIContext(FunctionCallInfo fcinfo)
+ * Utility function to read the upper memory context off a function call
+ * info data.
+ * This used to return flinfo->fn_mcxt (the function memory context) but that has the issue
+ * that is cleaned up once the function is finished, which on pure SQL functions (like ST_AsGML(geometry))
+ * is an issue as the cache will die after every _ST_AsGML call (thus being worthless).
+ * Instead we use CurTransactionContext which will live until the end of the transaction
+MemoryContext
+PostgisCacheContext(FunctionCallInfo fcinfo)
+	return CurTransactionContext;
+static GenericCacheCollection *internal_cache = NULL;
+static void
+PostgisResetInternalCache(void *v)
-	return fcinfo->flinfo->fn_mcxt;
+	internal_cache = NULL;
@@ -72,15 +86,19 @@ FIContext(FunctionCallInfo fcinfo)
 GetGenericCacheCollection(FunctionCallInfo fcinfo)
-	GenericCacheCollection* cache = fcinfo->flinfo->fn_extra;
-	if ( ! cache )
+	if (!internal_cache)
-		cache = MemoryContextAlloc(FIContext(fcinfo), sizeof(GenericCacheCollection));
-		memset(cache, 0, sizeof(GenericCacheCollection));
-		fcinfo->flinfo->fn_extra = cache;
+		internal_cache = MemoryContextAlloc(PostgisCacheContext(fcinfo), sizeof(GenericCacheCollection));
+		memset(internal_cache, 0, sizeof(GenericCacheCollection));
+		MemoryContextCallback *cb =
+		    MemoryContextAlloc(PostgisCacheContext(fcinfo), sizeof(MemoryContextCallback));
+		cb->func = PostgisResetInternalCache;
+		cb->arg = NULL;
+		MemoryContextRegisterResetCallback(PostgisCacheContext(fcinfo), cb);
-	return cache;
+	return internal_cache;
@@ -97,17 +115,16 @@ GetPROJSRSCache(FunctionCallInfo fcinfo)
 	if ( ! cache )
 		/* Allocate in the upper context */
-		cache = MemoryContextAlloc(FIContext(fcinfo), sizeof(PROJPortalCache));
+		cache = MemoryContextAlloc(PostgisCacheContext(fcinfo), sizeof(PROJPortalCache));
 		if (cache)
 			POSTGIS_DEBUGF(3,
 				       "Allocating PROJCache for portal with transform() MemoryContext %p",
-				       FIContext(fcinfo));
+				       PostgisCacheContext(fcinfo));
 			memset(cache->PROJSRSCache, 0, sizeof(PROJSRSCacheItem) * PROJ_CACHE_ITEMS);
 			cache->type = PROJ_CACHE_ENTRY;
 			cache->PROJSRSCacheCount = 0;
-			cache->PROJSRSCacheContext = FIContext(fcinfo);
 			/* Store the pointer in GenericCache */
 			generic_cache->entry[PROJ_CACHE_ENTRY] = (GenericCache*)cache;
@@ -142,7 +159,7 @@ GetGeomCache(FunctionCallInfo fcinfo,
 	if ( ! cache )
-		old_context = MemoryContextSwitchTo(FIContext(fcinfo));
+		old_context = MemoryContextSwitchTo(PostgisCacheContext(fcinfo));
 		cache = cache_methods->GeomCacheAllocator();
 		MemoryContextSwitchTo(old_context);
@@ -201,7 +218,7 @@ GetGeomCache(FunctionCallInfo fcinfo,
 		/* Save the tree and supporting geometry in the cache */
 		/* memory context */
 		lwgeom = lwgeom_from_gserialized(geom);
 		cache->argnum = 0;
@@ -231,7 +248,7 @@ GetGeomCache(FunctionCallInfo fcinfo,
 		if ( cache->geom1 ) pfree(cache->geom1);
 		cache->geom1_size = VARSIZE(g1);
-		cache->geom1 = MemoryContextAlloc(FIContext(fcinfo), cache->geom1_size);
+		cache->geom1 = MemoryContextAlloc(PostgisCacheContext(fcinfo), cache->geom1_size);
 		memcpy(cache->geom1, g1, cache->geom1_size);
 	/* Argument two didn't match, so copy the new value in. */
@@ -239,7 +256,7 @@ GetGeomCache(FunctionCallInfo fcinfo,
 		if ( cache->geom2 ) pfree(cache->geom2);
 		cache->geom2_size = VARSIZE(g2);
-		cache->geom2 = MemoryContextAlloc(FIContext(fcinfo), cache->geom2_size);
+		cache->geom2 = MemoryContextAlloc(PostgisCacheContext(fcinfo), cache->geom2_size);
 		memcpy(cache->geom2, g2, cache->geom2_size);
@@ -256,7 +273,7 @@ ToastCacheGet(FunctionCallInfo fcinfo)
 	ToastCache* cache = (ToastCache*)(generic_cache->entry[entry_number]);
 	if (!cache)
-		cache = MemoryContextAllocZero(FIContext(fcinfo), sizeof(ToastCache));
+		cache = MemoryContextAllocZero(PostgisCacheContext(fcinfo), sizeof(ToastCache));
 		cache->type = entry_number;
 		generic_cache->entry[entry_number] = (GenericCache*)cache;
@@ -299,7 +316,7 @@ ToastCacheGetGeometry(FunctionCallInfo fcinfo, uint32_t argnum)
 			return arg->geom;
 		/* Take a copy into the upper context */
-		MemoryContext old_context = MemoryContextSwitchTo(FIContext(fcinfo));
+		MemoryContext old_context = MemoryContextSwitchTo(PostgisCacheContext(fcinfo));
 		arg->geom = (GSERIALIZED*)PG_DETOAST_DATUM_COPY(datum);
 		return arg->geom;
diff --git a/libpgcommon/lwgeom_cache.h b/libpgcommon/lwgeom_cache.h
index 745e178..4bdd310 100644
--- a/libpgcommon/lwgeom_cache.h
+++ b/libpgcommon/lwgeom_cache.h
@@ -30,6 +30,8 @@
 #define NUM_CACHE_ENTRIES 8
+/* Returns the MemoryContext used to store the caches */
+MemoryContext PostgisCacheContext(FunctionCallInfo fcinfo);
 * A generic GeomCache just needs space for the cache type,
diff --git a/libpgcommon/lwgeom_transform.c b/libpgcommon/lwgeom_transform.c
index cacccd1..9c9601c 100644
--- a/libpgcommon/lwgeom_transform.c
+++ b/libpgcommon/lwgeom_transform.c
@@ -54,7 +54,8 @@ typedef struct {
 } PjStrs;
 /* Internal Cache API */
-static LWPROJ *AddToPROJSRSCache(PROJPortalCache *PROJCache, int32_t srid_from, int32_t srid_to);
+static LWPROJ *
+AddToPROJSRSCache(FunctionCallInfo fcinfo, PROJPortalCache *PROJCache, int32_t srid_from, int32_t srid_to);
 static void DeleteFromPROJSRSCache(PROJPortalCache *PROJCache, uint32_t position);
 static void
@@ -345,7 +346,7 @@ GetProj4String(int32_t srid)
  * which is the definition for the other half of the transformation.
 static LWPROJ *
-AddToPROJSRSCache(PROJPortalCache *PROJCache, int32_t srid_from, int32_t srid_to)
 	MemoryContext oldContext;
@@ -363,7 +364,7 @@ AddToPROJSRSCache(PROJPortalCache *PROJCache, int32_t srid_from, int32_t srid_to
 	if (!pjstrs_has_entry(&to_strs))
 		elog(ERROR, "got NULL for SRID (%d)", srid_to);
-	oldContext = MemoryContextSwitchTo(PROJCache->PROJSRSCacheContext);
+	oldContext = MemoryContextSwitchTo(PostgisCacheContext(fcinfo));
 #if POSTGIS_PROJ_VERSION < 60
 	PJ *projection = palloc(sizeof(PJ));
@@ -452,10 +453,10 @@ AddToPROJSRSCache(PROJPortalCache *PROJCache, int32_t srid_from, int32_t srid_to
 	/* We register a new callback to delete the projection on exit */
 	MemoryContextCallback *callback =
-	    MemoryContextAlloc(PROJCache->PROJSRSCacheContext, sizeof(MemoryContextCallback));
 	callback->func = PROJSRSDestroyPJ;
 	callback->arg = (void *)projection;
-	MemoryContextRegisterResetCallback(PROJCache->PROJSRSCacheContext, callback);
+	MemoryContextRegisterResetCallback(PostgisCacheContext(fcinfo), callback);
 	PROJCache->PROJSRSCache[cache_position].srid_from = srid_from;
 	PROJCache->PROJSRSCache[cache_position].srid_to = srid_to;
@@ -502,7 +503,7 @@ GetPJUsingFCInfo(FunctionCallInfo fcinfo, int32_t srid_from, int32_t srid_to, LW
 	*pj = GetProjectionFromPROJCache(proj_cache, srid_from, srid_to);
 	if (*pj == NULL)
-		*pj = AddToPROJSRSCache(proj_cache, srid_from, srid_to);
+		*pj = AddToPROJSRSCache(fcinfo, proj_cache, srid_from, srid_to);
 	return pj != NULL;
diff --git a/libpgcommon/lwgeom_transform.h b/libpgcommon/lwgeom_transform.h
index 2d2cd2d..a8ecdb0 100644
--- a/libpgcommon/lwgeom_transform.h
+++ b/libpgcommon/lwgeom_transform.h
@@ -32,8 +32,6 @@ char *GetProj4String(int32_t srid);
 typedef void *ProjCache ;
-bool IsInPROJCache(ProjCache cache, int32_t srid_from, int32_t srid_to);
-PJ *GetPJFromPROJCache(ProjCache cache, int32_t srid_from, int32_t srid_to);
 int GetPJUsingFCInfo(FunctionCallInfo fcinfo, int32_t srid_from, int32_t srid_to, LWPROJ **pj);
 int spheroid_init_from_srid(FunctionCallInfo fcinfo, int32_t srid, SPHEROID *s);
 void srid_check_latlong(FunctionCallInfo fcinfo, int32_t srid);
Summary of changes:
 NEWS                           |  2 +-
 libpgcommon/lwgeom_cache.c     | 61 +++++++++++++++++++++++++++---------------
 libpgcommon/lwgeom_cache.h     |  2 ++
 libpgcommon/lwgeom_transform.c | 13 ++++-----
 libpgcommon/lwgeom_transform.h |  2 --
 5 files changed, 49 insertions(+), 31 deletions(-)
hooks/post-receive
