[postgis-tickets] [PostGIS] #4681: Have ST_GetFaceGeometry print a WARNING if face edges are found but no polygon can be built
trac at osgeo.org
Mon May 4 09:02:35 PDT 2020
Reporter: strk | Owner: strk
Type: enhancement | Status: closed
Priority: medium | Milestone:
Component: topology | Version: master
Resolution: fixed | Keywords:
Changes (by Sandro Santilli <strk@…>):
* status: new => closed
* resolution: => fixed
Comment:
In [changeset:"943cda089b3dd74b68c805cb935cb00f4a044e43/git" 943cda0/git]:
#!CommitTicketReference repository="git"
revision="943cda089b3dd74b68c805cb935cb00f4a044e43"
ST_GetFaceGeometry: always print corruption information
Use NOTICE when an exception will prevent ValidateTopology
from completing (see #3221).
Also return EMPTY instead of NULL on corruption due to
partial boundaries (consistently with face without
boundaries reported in #3221)
Includes testcase and NEWS item.
Closes #4681
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4681#comment:2>
