[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0alpha1-102-g10c405f
git at osgeo.org
git at osgeo.org
Mon May 4 09:19:36 PDT 2020
the project "PostGIS".
via 10c405f3faa48485354be22dc648daafb5a0b3f4 (commit)
from 943cda089b3dd74b68c805cb935cb00f4a044e43 (commit)
revisions in full, below.
commit 10c405f3faa48485354be22dc648daafb5a0b3f4
Author: Raúl Marín <git at rmr.ninja>
Date: Mon May 4 12:37:33 2020 +0200
Revert "Internal cache now persists until the end of the transaction"
This reverts commit 3ced96fc1a79831a26c33311a17d1f32e3c5c732.
References #4674
Closes https://github.com/postgis/postgis/pull/560
diff --git a/NEWS b/NEWS
index 5f62cb1..a7a0886 100644
--- a/NEWS
+++ b/NEWS
@@ -4,7 +4,7 @@ PostGIS 3.1.0XXXX
Only tickets not included in 3.1.0alpha1
* Breaking changes *
- - #4674, Internal cache now persists until the end of the transaction (Raúl Marín)
* New features *
- #4656, Cast a geojson_text::geometry for implicit GeoJSON ingestion (Raúl Marín)
diff --git a/libpgcommon/lwgeom_cache.c b/libpgcommon/lwgeom_cache.c
index d505021..6ca313b 100644
--- a/libpgcommon/lwgeom_cache.c
+++ b/libpgcommon/lwgeom_cache.c
@@ -62,23 +62,13 @@ typedef struct {
* Utility function to read the upper memory context off a function call
* info data.
- * This used to return flinfo->fn_mcxt (the function memory context) but that has the issue
- * that is cleaned up once the function is finished, which on pure SQL functions (like ST_AsGML(geometry))
- * is an issue as the cache will die after every _ST_AsGML call (thus being worthless).
- * Instead we use CurTransactionContext which will live until the end of the transaction
MemoryContext
PostgisCacheContext(FunctionCallInfo fcinfo)
- return CurTransactionContext;
-static GenericCacheCollection *internal_cache = NULL;
-static void
-PostgisResetInternalCache(void *v)
- internal_cache = NULL;
+ if (!fcinfo->flinfo)
+ elog(ERROR, "%s: Could not find upper context", __func__);
+ return fcinfo->flinfo->fn_mcxt;
@@ -88,18 +78,17 @@ PostgisResetInternalCache(void *v)
GetGenericCacheCollection(FunctionCallInfo fcinfo)
+ GenericCacheCollection *internal_cache;
+ internal_cache = fcinfo->flinfo->fn_extra;
if (!internal_cache)
- internal_cache = MemoryContextAlloc(PostgisCacheContext(fcinfo), sizeof(GenericCacheCollection));
- memset(internal_cache, 0, sizeof(GenericCacheCollection));
- MemoryContextCallback *cb =
- MemoryContextAlloc(PostgisCacheContext(fcinfo), sizeof(MemoryContextCallback));
- cb->func = PostgisResetInternalCache;
- cb->arg = NULL;
- MemoryContextRegisterResetCallback(PostgisCacheContext(fcinfo), cb);
+ internal_cache = MemoryContextAllocZero(PostgisCacheContext(fcinfo), sizeof(GenericCacheCollection));
+ fcinfo->flinfo->fn_extra = internal_cache;
return internal_cache;
diff --git a/postgis/lwgeom_inout.c b/postgis/lwgeom_inout.c
index 0757de0..8ce752d 100644
--- a/postgis/lwgeom_inout.c
+++ b/postgis/lwgeom_inout.c
@@ -658,8 +658,10 @@ Datum parse_WKT_lwgeom(PG_FUNCTION_ARGS)
/* Unwrap the PgSQL text type into a cstring */
wkt = text_to_cstring(wkt_text);
- /* Now we call over to the geometry_in function */
- result = DirectFunctionCall1(LWGEOM_in, CStringGetDatum(wkt));
+ /* Now we call over to the geometry_in function
+ * We need to initialize the fcinfo since cache might be used
+ result = CallerFInfoFunctionCall1(LWGEOM_in, fcinfo->flinfo, InvalidOid, CStringGetDatum(wkt));
/* Return null on null */
if ( ! result )
Summary of changes:
NEWS | 2 +-
libpgcommon/lwgeom_cache.c | 33 +++++++++++----------------------
postgis/lwgeom_inout.c | 6 ++++--
3 files changed, 16 insertions(+), 25 deletions(-)
hooks/post-receive
