the project "PostGIS".
via 5cea21d4ade82fa18a321a629892b0550f1ed398 (commit)
from 10d2f810601b7c226fab12848f943479dd3d53b1 (commit)
revisions in full, below.
commit 5cea21d4ade82fa18a321a629892b0550f1ed398
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Fri May 8 11:17:36 2020 -0700
move declarations to top of block (c90), references #4687
diff --git a/postgis/lwgeom_geos.c b/postgis/lwgeom_geos.c
index 47054d7..6f7b2fb 100644
--- a/postgis/lwgeom_geos.c
+++ b/postgis/lwgeom_geos.c
@@ -384,47 +384,49 @@ Datum ST_MaximumInscribedCircle(PG_FUNCTION_ARGS)
else
- GEOSGeometry *g1;
- GEOSGeometry *g2;
+ GEOSGeometry *ginput, *gcircle, *gcenter, *gnearest;
+ double width, height, size, tolerance;
GBOX gbox;
+ int gtype;
if (!gserialized_get_gbox_p(geom, &gbox))
PG_RETURN_NULL();
- initGEOS(lwpgnotice, lwgeom_geos_error);
+ width = gbox.xmax - gbox.xmin;
+ height = gbox.ymax - gbox.ymin;
+ size = width > height ? width : height;
+ tolerance = size / 1000.0;
- double width = gbox.xmax - gbox.xmin;
- double height = gbox.ymax - gbox.ymin;
- double size = width > height ? width : height;
- double tolerance = size / 1000.0;
+ initGEOS(lwpgnotice, lwgeom_geos_error);
- g1 = POSTGIS2GEOS(geom);
- if (!g1)
+ ginput = POSTGIS2GEOS(geom);
+ if (!ginput)
HANDLE_GEOS_ERROR("Geometry could not be converted to GEOS");
- int gtype = gserialized_get_type(geom);
+ gtype = gserialized_get_type(geom);
if (gtype == POLYGONTYPE || gtype == MULTIPOLYGONTYPE)
- g2 = GEOSMaximumInscribedCircle(g1, tolerance);
- if (!g2)
+ gcircle = GEOSMaximumInscribedCircle(ginput, tolerance);
+ if (!gcircle)
lwpgerror("Error calculating GEOSMaximumInscribedCircle.");
- GEOSGeom_destroy(g1);
+ GEOSGeom_destroy(ginput);
PG_RETURN_NULL();
else
- g2 = GEOSLargestEmptyCircle(g1, NULL, tolerance);
- if (!g2)
+ gcircle = GEOSLargestEmptyCircle(ginput, NULL, tolerance);
+ if (!gcircle)
lwpgerror("Error calculating GEOSLargestEmptyCircle.");
PG_RETURN_NULL();
- GEOSGeometry *gcenter = GEOSGeomGetStartPoint(g2);
- GEOSGeometry *gnearest = GEOSGeomGetEndPoint(g2);
+ gcenter = GEOSGeomGetStartPoint(gcircle);
+ gnearest = GEOSGeomGetEndPoint(gcircle);
GEOSDistance(gcenter, gnearest, &radius);
GEOSSetSRID(gcenter, srid);
GEOSSetSRID(gnearest, srid);
@@ -433,8 +435,8 @@ Datum ST_MaximumInscribedCircle(PG_FUNCTION_ARGS)
nearest = GEOS2POSTGIS(gnearest, is3d);
GEOSGeom_destroy(gcenter);
GEOSGeom_destroy(gnearest);
- GEOSGeom_destroy(g2);
+ GEOSGeom_destroy(gcircle);
get_call_result_type(fcinfo, NULL, &resultTupleDesc);
Summary of changes:
postgis/lwgeom_geos.c | 42 ++++++++++++++++++++++--------------------
1 file changed, 22 insertions(+), 20 deletions(-)
hooks/post-receive
