[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0alpha1-117-g4e431eb
Mon May 11 16:22:22 PDT 2020
the project "PostGIS".
       via  4e431eb6b4b63ced545d66641236bcac855b8fba (commit)
      from  4d064baf7cf1b61bbf4649af0c8501ec7f286ccf (commit)
revisions in full, below.
commit 4e431eb6b4b63ced545d66641236bcac855b8fba
Author: Regina Obe <lr at pcorp.us>
Date:   Mon May 11 19:22:17 2020 -0400
    Add note that ST_Point and ST_MakePoint are faster for points as pointed out by God
diff --git a/doc/reference_input.xml b/doc/reference_input.xml
index a275a00..9087f13 100644
--- a/doc/reference_input.xml
+++ b/doc/reference_input.xml
@@ -383,6 +383,43 @@ SELECT ST_GeomFromEWKT('POLYHEDRALSURFACE(
 			<para>&sfs_compliant; s3.2.6.2 - option SRID is from the conformance suite.</para>
 			<para>&sqlmm_compliant; SQL-MM 3: 5.1.40</para>
 			<para>&curve_support;</para>
+	<refentry id="ST_GeomFromText">
+		  <refnamediv>
+			<refname>ST_GeomFromText</refname>
+			<refpurpose>Return a specified ST_Geometry value from Well-Known Text representation (WKT).</refpurpose>
+		  </refnamediv>
+		  <refsynopsisdiv>
+			<funcsynopsis>
+			  <funcprototype>
+				<funcdef>geometry <function>ST_GeomFromText</function></funcdef>
+				<paramdef><type>text </type> <parameter>WKT</parameter></paramdef>
+			  </funcprototype>
+			  <funcprototype>
+				<paramdef><type>integer </type> <parameter>srid</parameter></paramdef>
+			  </funcprototype>
+			</funcsynopsis>
+		  </refsynopsisdiv>
+		  <refsection>
+			<title>Description</title>
+			<para>Constructs a PostGIS ST_Geometry object from the OGC Well-Known text representation.</para>
+			<!-- optionally mention that this function uses indexes if appropriate -->
+			<note>
+				<para>There are two variants of ST_GeomFromText function.  The first takes no SRID and returns a geometry
+					with no defined spatial reference system (SRID=0).  The second takes a SRID as the second argument
+					and returns a geometry that includes this SRID as part of its metadata.
+				</para>
+			</note>
+			<para>&sfs_compliant; s3.2.6.2 - option SRID is from the conformance suite.</para>
+			<para>&sqlmm_compliant; SQL-MM 3: 5.1.40</para>
+			<para>&curve_support;</para>
+            <note><para>While not OGC-compliant, <xref linkend="ST_MakePoint" /> is faster than ST_GeomFromText and ST_PointFromText. It is also easier to use for numeric coordinate values. <xref linkend="ST_Point" /> is another option similar in speed to <xref linkend="ST_Point" /> and is OGC-compliant, but doesn't support anything but 2D points.</para></note>
 			<warning><para>Changed: 2.0.0 In prior versions of PostGIS ST_GeomFromText('GEOMETRYCOLLECTION(EMPTY)') was allowed.  This is now illegal in PostGIS 2.0.0 to better conform with SQL/MM standards. This should now be
 			    written as ST_GeomFromText('GEOMETRYCOLLECTION EMPTY')</para></warning>
Summary of changes:
 doc/reference_input.xml | 37 +++++++++++++++++++++++++++++++++++++
 1 file changed, 37 insertions(+)
hooks/post-receive
