[postgis-tickets] [PostGIS] #4684: concurrent topology construction routine may result in invalid topology (was: Topology construction routine results invalid topology)
trac at osgeo.org
Fri May 15 00:06:05 PDT 2020
Reporter: laopsahl | Owner: strk
Type: defect | Status: new
Priority: medium | Milestone:
Component: topology | Version: 3.0.x
Resolution: | Keywords:
Changes (by strk):
* owner: pramsey => strk
* component: postgis => topology
Comment:
There might be a way, using PostgreSQL locks, to reduce the chances (or
completely avoid) that such invalidities are introduced in the topology.
Serializing access to the topology primitives could be overkill becuase it
would prevent the 3 steps approach above. What we want to avoid is that
more than ONE transaction at the time works on the same edges. Row level
locks might help with that: https://www.postgresql.org/docs/10/explicit-
locking.html#LOCKING-ROWS
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4684#comment:5>
