[postgis-tickets] [PostGIS] #4690: Line Clipping MVT failure?
trac at osgeo.org
Sat May 16 02:50:38 PDT 2020
Reporter: pramsey | Owner: Algunenano
Type: defect | Status: assigned
Priority: medium | Milestone: PostGIS 3.0.2
Component: postgis | Version: 3.0.x
Resolution: | Keywords:
Comment (by Algunenano):
A couple of notes:
- Line clipping uses GEOS in all versions; wagyu is only used for polygons
in 3.0+
- It seems like the issue is found in lwgeom_clip_by_rect, so the first
thing I would do is to extract the offending geometry and the the clipping
values (those we can already see in the callstack) to try to see what's
going on in there.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4690#comment:2>
