[postgis-tickets] [PostGIS] #4693: PostGIS 3.1.0 still showing 3.1.0alpha1 in output
trac at osgeo.org
Sat May 23 16:25:16 PDT 2020
Reporter: robe | Owner: robe
Type: defect | Status: assigned
Priority: blocker | Milestone: PostGIS 3.1.0
Component: build/upgrade/install | Version: master
Keywords: |
I thought I ticked this before - but noticing this on the outputs
PostgreSQL 13beta1, compiled by Visual C++ build 1914, 64-bit
Postgis 3.1.0dev - (3.1.0alpha1-122-g16121bf79) - 2020-05-23 22:57:55
scripts 3.1.0dev 3.1.0alpha1-122-g16121bf79
GEOS: 3.9.0-CAPI-1.14.0
PROJ: Rel. 5.2.0, September 15th, 2018
So I assume when I flipped the version number I missed a spot?
SELECT postgis_full_version();
shows similar ugliness
On my workstation shows this
POSTGIS="3.1.0dev 3.1.0alpha1-122-g16121bf79" [EXTENSION] PGSQL="130"
GEOS="3.9.0-CAPI-1.14.0" SFCGAL="1.3.2" PROJ="6.2.1" GDAL="GDAL 3.0.2,
released 2019/10/28" LIBXML="2.9.9" LIBJSON="0.12" LIBPROTOBUF="1.2.1"
WAGYU="0.5.0 (Internal)" TOPOLOGY RASTER
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4693>
