[postgis-tickets] [SCM] PostGIS branch stable-2.3 updated. 545ddc39b19cd31c90596052f30ca528b10155ff
Sun May 31 10:31:56 PDT 2020
the project "PostGIS".
The branch, stable-2.3 has been updated
       via  545ddc39b19cd31c90596052f30ca528b10155ff (commit)
      from  2d13f51d9bb288f52c12f7595f802efd5719c80b (commit)
revisions in full, below.
commit 545ddc39b19cd31c90596052f30ca528b10155ff
Author: Regina Obe <lr at pcorp.us>
Date:   Sun May 31 13:31:50 2020 -0400
    Change intersection test slightly so gives the same answer on all versions of sfcgal
diff --git a/regress/regress_ogc.sql b/regress/regress_ogc.sql
index 7853bc2..ec726ac 100644
--- a/regress/regress_ogc.sql
+++ b/regress/regress_ogc.sql
@@ -157,7 +157,7 @@ SELECT 'overlaps', ST_overlaps('POLYGON((0 0, 0 10, 10 10, 10 0, 0 0))'::geometr
 SELECT 'isvalid', ST_isvalid('POLYGON((0 0, 0 10, 10 10, 10 0, 0 0))'::geometry);
 SELECT 'isvalid', ST_isvalid('POLYGON((0 0, 0 10, 10 10, -5 10, 10 0, 0 0))'::geometry);
 SELECT 'isvalid', ST_isvalid('GEOMETRYCOLLECTION EMPTY'::geometry);
-SELECT 'intersection', ST_astext(ST_intersection('LINESTRING(0 10, 0 0, 0 5)'::geometry, 'LINESTRING(0 1, 1 1)'::geometry));
+SELECT 'intersection', ST_astext(ST_intersection('LINESTRING(0 10, 0.0 0, 0 5)'::geometry, 'LINESTRING(0 1, 1 1)'::geometry));
 SELECT 'difference', ST_astext(ST_difference('LINESTRING(0 10, 0 -10)'::GEOMETRY, 'LINESTRING(0 2, 0 -2)'::GEOMETRY));
 SELECT 'boundary', ST_astext(ST_boundary('POLYGON((0 0, 0 10, 10 10, 10 0, 0 0),(2 2, 2 4, 4 4, 4 2, 2 2))'::geometry));
 SELECT 'symdifference', ST_astext(ST_symdifference('POLYGON((0 0, 0 10, 10 10, 10 0, 0 0),(2 2, 2 4, 4 4, 4 2, 2 2))'::geometry, 'LINESTRING(0 0, 20 20)'::geometry));
Summary of changes:
 regress/regress_ogc.sql | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
hooks/post-receive
