[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0alpha2-74-g962ef92
Sun Oct 4 12:48:09 PDT 2020
the project "PostGIS".
       via  962ef92215fdac72b317d7d99201931394174afa (commit)
      from  372095d9ae9090400e81167097ed0d9d836c0a7a (commit)
revisions in full, below.
commit 962ef92215fdac72b317d7d99201931394174afa
Author: Regina Obe <lr at pcorp.us>
Date:   Sun Oct 4 15:47:44 2020 -0400
    Split postgis-sfcgal lib from postgis lib, closes #4258
    closes https://git.osgeo.org/gitea/postgis/postgis/pulls/48
diff --git a/.gitignore b/.gitignore
index c4388f9..5405e32 100644
--- a/.gitignore
+++ b/.gitignore
@@ -152,6 +152,9 @@ regress/sfcgal/Makefile
 regress/postgis.sql
 regress/postgis_garden_result.txt
 regress/raster_garden_result.txt
+sfcgal/Makefile
+sfcgal/*.sql
+sfcgal/sfcgal_upgrade.sql.in
 *.so
 .svn
diff --git a/GNUmakefile.in b/GNUmakefile.in
index 7b10f3b..7562648 100644
--- a/GNUmakefile.in
+++ b/GNUmakefile.in
@@ -6,7 +6,7 @@
 SUBDIRS = liblwgeom
 ifeq (@LIBLWGEOM_ONLY@,no)
-SUBDIRS += libpgcommon postgis regress @RASTER@ @TOPOLOGY@ loader utils doc @EXTENSIONS@ @DEPS_SUBDIR@
+SUBDIRS += libpgcommon postgis regress @RASTER@ @TOPOLOGY@ @SFCGAL@ loader utils doc @EXTENSIONS@ @DEPS_SUBDIR@
 endif
 POSTGIS_MAJOR_VERSION=@POSTGIS_MAJOR_VERSION@
diff --git a/NEWS b/NEWS
index 9a352a3..681f1b0 100644
--- a/NEWS
+++ b/NEWS
@@ -1,9 +1,10 @@
-PostGIS 3.1.0beta1
+PostGIS 3.1.0alpha3
 2020/xx/xx
 Only tickets not included in 3.1.0alpha2
 * Breaking changes *
   - #4737, Bump minimum protobuf-c requirement to 1.1.0 (Raúl Marín)
+  - #4258, Untangle postgis_sfcgal into its own .so (Regina Obe)
 * New features *
   - #4698, Add a precision parameter to ST_AsEWKT (Raúl Marín)
diff --git a/configure.ac b/configure.ac
index 0abd06b..91ccd9c 100644
--- a/configure.ac
+++ b/configure.ac
@@ -1586,6 +1586,7 @@ AC_OUTPUT([GNUmakefile
    libpgcommon/cunit/Makefile
    postgis/Makefile
    postgis/sqldefines.h
+	 sfcgal/Makefile
    loader/Makefile
    loader/cunit/Makefile
    topology/Makefile
diff --git a/extensions/postgis_sfcgal/Makefile.in b/extensions/postgis_sfcgal/Makefile.in
index cd71bc9..dd7ca48 100644
--- a/extensions/postgis_sfcgal/Makefile.in
+++ b/extensions/postgis_sfcgal/Makefile.in
@@ -62,7 +62,7 @@ sql/$(EXTENSION)--$(EXTVERSION).sql: $(EXTENSION_SCRIPTS) | sql
 	printf '\\echo Use "CREATE EXTENSION $(EXTENSION)" to load this file. \\quit\n' > $@
 	cat $^ > $@
-sql_bits/sfcgal.sql: ../../postgis/sfcgal.sql
+sql_bits/sfcgal.sql: ../../sfcgal/sfcgal.sql
 	mkdir -p sql_bits
 	$(PERL) -pe 's/BEGIN\;//g ; s/COMMIT\;//g' $< > $@
@@ -83,7 +83,7 @@ sql/$(EXTENSION)--unpackaged--$(EXTVERSION).sql: $(EXTENSION_UNPACKAGED_UPGRADE_
 		| $(PERL) ../../utils/create_unpackaged.pl ${EXTENSION} \
-sql_bits/sfcgal_upgrade.sql : ../../postgis/sfcgal_upgrade.sql
+sql_bits/sfcgal_upgrade.sql : ../../sfcgal/sfcgal_upgrade.sql
 	mkdir -p sql_bits
diff --git a/postgis/Makefile.in b/postgis/Makefile.in
index b29047a..b78e0ad 100644
--- a/postgis/Makefile.in
+++ b/postgis/Makefile.in
@@ -18,6 +18,7 @@
+# * Copyright 2020 Regina Obe
 # * Copyright 2008 Mark Cave-Ayland
@@ -41,17 +42,10 @@ DATA=../spatial_ref_sys.sql
 SQL_objs=postgis.sql legacy.sql legacy_minimal.sql
 GEOM_BACKEND_OBJ = lwgeom_geos.o
-SFCGAL_BACKEND_OBJ = lwgeom_sfcgal.o
-ifeq (@SFCGAL@,sfcgal)
-DATA_built=$(SQL_built) sfcgal.sql sfcgal_upgrade.sql uninstall_sfcgal.sql
-SQL_OBJS=$(SQL_objs) sfcgal.sql
-BACKEND_OBJ=$(GEOM_BACKEND_OBJ) $(SFCGAL_BACKEND_OBJ)
-else
-endif
 ifeq (@HAVE_SPGIST@,yes)
 SPGIST_OBJ= gserialized_spgist_2d.o gserialized_spgist_3d.o gserialized_spgist_nd.o
@@ -146,12 +140,6 @@ OBJS=$(PG_OBJS)
 PG_CPPFLAGS += -I../liblwgeom @CFLAGS@ -I../libpgcommon $(WAYGU_INCLUDE) $(UTHASH_INCLUDE) @CPPFLAGS@ @PICFLAGS@
 SHLIB_LINK_F = $(WAYGU_LIB) ../libpgcommon/libpgcommon.a ../liblwgeom/.libs/liblwgeom.a @SHLIB_LINK@
-# Add SFCGAL Flags if defined
-PG_CPPFLAGS += @SFCGAL_CPPFLAGS@
-SHLIB_LINK_F += @SFCGAL_LDFLAGS@
-endif
 # Extra files to remove during 'make clean'
 EXTRA_CLEAN=$(SQL_OBJS) \
 	uninstall_postgis.sql \
@@ -159,8 +147,6 @@ EXTRA_CLEAN=$(SQL_OBJS) \
 	uninstall_sfcgal.sql \
 	postgis_upgrade.sql.in \
 	postgis_upgrade.sql \
-	sfcgal_upgrade.sql.in \
-	sfcgal_upgrade.sql \
 	vector_tile.pb-c.c \
 	vector_tile.pb-c.h \
 	geobuf.pb-c.c \
@@ -254,12 +240,6 @@ postgis_upgrade.sql: postgis_before_upgrade.sql postgis_upgrade.sql.in postgis_a
 	cat $^ >> $@
 	echo "COMMIT;" >> $@
-sfcgal_upgrade.sql.in: sfcgal.sql ../utils/postgis_proc_upgrade.pl
-	$(PERL) ../utils/postgis_proc_upgrade.pl $< UNUSED > $@
-sfcgal_upgrade.sql: sfcgal_upgrade.sql.in postgis_after_upgrade.sql
-	cat $^ > $@
 # SQL objects are also dependent on postgis_config.h for PostgreSQL version
 $(SQL_OBJS): ../postgis_config.h ../postgis_revision.h
@@ -271,9 +251,6 @@ uninstall_postgis.sql: postgis.sql ../utils/create_undef.pl
 uninstall_legacy.sql: legacy.sql ../utils/create_undef.pl
 	$(PERL) ../utils/create_undef.pl $< $(POSTGIS_PGSQL_VERSION) > $@
-uninstall_sfcgal.sql: sfcgal.sql ../utils/create_undef.pl
-	$(PERL) ../utils/create_undef.pl $< $(POSTGIS_PGSQL_VERSION) > $@
 distclean: clean
 	rm -f Makefile
diff --git a/postgis/postgis_legacy.c b/postgis/postgis_legacy.c
index cb3b001..de663e6 100644
--- a/postgis/postgis_legacy.c
+++ b/postgis/postgis_legacy.c
@@ -18,7 +18,7 @@
- * Copyright (C) 2018 Regina Obe <lr at pcorp.us>
+ * Copyright (C) 2018-2020 Regina Obe <lr at pcorp.us>
@@ -77,3 +77,25 @@ POSTGIS_DEPRECATE("3.0.0", intersects);
 POSTGIS_DEPRECATE("3.0.0", pgis_geometry_accum_finalfn);
 POSTGIS_DEPRECATE("3.0.0", postgis_autocache_bbox);
 POSTGIS_DEPRECATE("2.0.0", postgis_uses_stats);
+/**Start: SFCGAL functions moved to postgis_sfcgal lib, to ease pg_upgrade **/
+/**: TODO these can be taken out in a later release once PostGIS 3.0 is EOLd **/
+POSTGIS_DEPRECATE("3.1.0", sfcgal_from_ewkt);
+POSTGIS_DEPRECATE("3.1.0", sfcgal_area3D);
+POSTGIS_DEPRECATE("3.1.0", sfcgal_intersection3D);
+POSTGIS_DEPRECATE("3.1.0", sfcgal_difference3D);
+POSTGIS_DEPRECATE("3.1.0", sfcgal_union3D);
+POSTGIS_DEPRECATE("3.1.0", sfcgal_volume);
+POSTGIS_DEPRECATE("3.1.0", sfcgal_extrude);
+POSTGIS_DEPRECATE("3.1.0", sfcgal_straight_skeleton);
+POSTGIS_DEPRECATE("3.1.0", sfcgal_approximate_medial_axis);
+POSTGIS_DEPRECATE("3.1.0", sfcgal_is_planar);
+POSTGIS_DEPRECATE("3.1.0", sfcgal_orientation);
+POSTGIS_DEPRECATE("3.1.0", sfcgal_force_lhr);
+POSTGIS_DEPRECATE("3.1.0", ST_ConstrainedDelaunayTriangles);
+POSTGIS_DEPRECATE("3.1.0", sfcgal_tesselate);
+POSTGIS_DEPRECATE("3.1.0", sfcgal_minkowski_sum);
+POSTGIS_DEPRECATE("3.1.0", sfcgal_make_solid);
+POSTGIS_DEPRECATE("3.1.0", sfcgal_is_solid);
+POSTGIS_DEPRECATE("3.1.0", postgis_sfcgal_noop);
+/**End: SFCGAL functions moved to postgis_sfcgal lib, to ease pg_upgrade **/
diff --git a/regress/Makefile.in b/regress/Makefile.in
index d02beb7..7fe9bae 100644
--- a/regress/Makefile.in
+++ b/regress/Makefile.in
@@ -60,6 +60,11 @@ distclean: clean
 	$(MAKE) -C sfcgal $@
 	rm -f Makefile
+staged-install-sfcgal:
+	@if test x"@SFCGAL@" != "x"; then \
+		$(MAKE) -C ../sfcgal REGRESS=1 DESTDIR=$(REGRESS_INSTALLDIR) install; \
+	fi
 staged-install-topology:
 	@if test x"@TOPOLOGY@" != "x"; then \
 		$(MAKE) -C ../topology REGRESS=1 DESTDIR=$(REGRESS_INSTALLDIR) install; \
@@ -70,7 +75,7 @@ staged-install-raster:
 		$(MAKE) -C ../raster/rt_pg REGRESS=1 DESTDIR=$(REGRESS_INSTALLDIR) install; \
 	fi
-staged-install: staged-install-raster staged-install-topology
+staged-install: staged-install-raster staged-install-topology staged-install-sfcgal
 	$(MAKE) -C ../postgis REGRESS=1 DESTDIR=$(REGRESS_INSTALLDIR) install
 	$(MAKE) -C ../ REGRESS=1 DESTDIR=$(REGRESS_INSTALLDIR) comments-install
 	$(PERL) -pi -e 's,\$$libdir,$(REGRESS_INSTALLDIR)/lib,g' $(REGRESS_INSTALLDIR)/share/contrib/postgis/*.sql
diff --git a/sfcgal/Makefile.in b/sfcgal/Makefile.in
new file mode 100644
index 0000000..517209c
--- /dev/null
+++ b/sfcgal/Makefile.in
@@ -0,0 +1,169 @@
+# * PostGIS - Spatial Types for PostgreSQL
+# * http://postgis.net
+# * PostGIS is free software: you can redistribute it and/or modify
+# * it under the terms of the GNU General Public License as published by
+# * the Free Software Foundation, either version 2 of the License, or
+# * (at your option) any later version.
+# * PostGIS is distributed in the hope that it will be useful,
+# * but WITHOUT ANY WARRANTY; without even the implied warranty of
+# * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
+# * GNU General Public License for more details.
+# * You should have received a copy of the GNU General Public License
+# * along with PostGIS.  If not, see <http://www.gnu.org/licenses/>.
+# * Copyright 2008 Mark Cave-Ayland
+MODULE_NAME=postgis_sfcgal
+MODULE_big=$(MODULE_NAME)- at POSTGIS_MAJOR_VERSION@
+MODULEDIR=contrib/postgis- at POSTGIS_MAJOR_VERSION@. at POSTGIS_MINOR_VERSION@
+MODULEPATH=$$libdir/$(MODULE_NAME)- at POSTGIS_MAJOR_VERSION@
+POSTGIS_PGSQL_VERSION=@POSTGIS_PGSQL_VERSION@
+ifeq (@LIBINCLUDEMINORVERSION@,yes)
+MODULEPATH=$$libdir/$(MODULE_NAME)- at POSTGIS_MAJOR_VERSION@. at POSTGIS_MINOR_VERSION@
+MODULE_big=$(MODULE_NAME)- at POSTGIS_MAJOR_VERSION@. at POSTGIS_MINOR_VERSION@
+endif
+# Files to be copied to the contrib/ directory
+DATA_built=sfcgal.sql uninstall_sfcgal.sql sfcgal_upgrade.sql
+DATA=
+# SQL preprocessor
+SQLPP = @SQLPP@
+# SQL objects (files requiring pre-processing)
+SQL_OBJS = \
+  sfcgal.sql \
+	sfcgal_upgrade.sql.in \
+  sfcgal_upgrade.sql \
+  sfcgal_after_upgrade.sql \
+  sfcgal_before_upgrade.sql
+# Objects to build using PGXS
+OBJS = lwgeom_sfcgal.o
+# Libraries to link into the module (proj, geos)
+# Note: we specify liblwgeom.a directly in SHLIB_LINK rather than using
+# -L... -l options to prevent issues with some platforms trying to link
+# to an existing liblwgeom.so in the PostgreSQL $libdir supplied by an
+# older version of PostGIS, rather than with the static liblwgeom.a
+# supplied with newer versions of PostGIS
+PG_CPPFLAGS += -I../liblwgeom -I../libpgcommon @CFLAGS@ @CPPFLAGS@ @PICFLAGS@
+SHLIB_LINK_F = ../libpgcommon/libpgcommon.a ../liblwgeom/.libs/liblwgeom.a @SHLIB_LINK@
+# Add SFCGAL Flags if defined
+ifeq (@SFCGAL@,sfcgal)
+PG_CPPFLAGS += @SFCGAL_CPPFLAGS@
+SHLIB_LINK_F += @SFCGAL_LDFLAGS@
+endif
+# Set PERL _after_ the include of PGXS
+PERL=@PERL@
+# This is to workaround a bug in PGXS 8.4 win32 link line,
+# see http://trac.osgeo.org/postgis/ticket/1158#comment:57
+SHLIB_LINK := $(SHLIB_LINK_F) $(SHLIB_LINK)
+# PGXS information
+PG_CONFIG := @PG_CONFIG@
+PGXS := @PGXS@
+$(OBJS): ../liblwgeom/.libs/liblwgeom.a ../libpgcommon/libpgcommon.a ../postgis_config.h
+endif
+# Extra files to remove during 'make clean'
+EXTRA_CLEAN=$(SQL_OBJS) \
+	uninstall_sfcgal.sql
+# PGXS information
+PGXS := @PGXS@
+# NO_TEMP_INSTALL is a workaround for a 9.5dev bug. See:
+# http://www.postgresql.org/message-id/CAB7nPqTsR5o3g-fBi6jbsVdhfPiLFWQ_0cGU5=94Rv_8W3qvFA@mail.gmail.com
+NO_TEMP_INSTALL=yes
+include $(PGXS)
+PERL=@PERL@
+# NOTE: setting LDFLAGS explicitly here avoids getting the
+# link line polluted by unrelated PostgreSQL switches that
+# may be confusing and out-of-control for the builder of
+# PostGIS
+LDFLAGS = @LDFLAGS@
+# If REGRESS=1 passed as a parameter, change the default install paths
+# so that no prefix is included. This allows us to relocate to a temporary
+# directory for regression testing.
+ifeq ($(REGRESS),1)
+	bindir=/bin
+	pkglibdir=/lib
+	datadir=/share
+	datamoduledir=contrib/postgis
+endif
+# Make all PostGIS objects depend upon liblwgeom, so that if an underlying
+# change is made, a PostGIS rebuild is triggered.
+# Also they are all dependent on postgis_config.h
+# and thus postgis_revision.h
+$(PG_OBJS): ../liblwgeom/.libs/liblwgeom.a ../libpgcommon/libpgcommon.a ../postgis_config.h ../postgis_revision.h
+# Borrow the $libdir substitution from PGXS but customise by running the preprocessor
+# and adding the version number
+# replace @extschema at . with nothing, this is only used as placeholder for extension install
+%.sql: %.sql.in
+	$(SQLPP) -I../libpgcommon $< | grep -v '^#' | \
+	$(PERL) -lpe "s'MODULE_PATHNAME'\$(MODULEPATH)'g;s'@extschema@\.''g" > $@
+sfcgal_upgrade.sql.in: sfcgal.sql ../utils/postgis_proc_upgrade.pl
+	$(PERL) ../utils/postgis_proc_upgrade.pl $< UNUSED > $@
+sfcgal_upgrade.sql: sfcgal_before_upgrade.sql sfcgal_upgrade.sql.in sfcgal_after_upgrade.sql
+	echo "BEGIN;" > $@
+	cat $^ >> $@
+	echo "COMMIT;" >> $@
+uninstall_sfcgal_legacy.sql: sfcgal_legacy.sql ../utils/create_undef.pl
+	$(PERL) ../utils/create_undef.pl $< $(POSTGIS_PGSQL_VERSION) > $@
+uninstall_sfcgal.sql: sfcgal.sql ../utils/create_undef.pl
+distclean: clean
+	rm -f Makefile
+check-unit:
+check-regress:
+maintainer-clean: distclean
diff --git a/postgis/lwgeom_sfcgal.c b/sfcgal/lwgeom_sfcgal.c
similarity index 91%
rename from postgis/lwgeom_sfcgal.c
rename to sfcgal/lwgeom_sfcgal.c
index 6ab8afa..3e3729b 100644
--- a/postgis/lwgeom_sfcgal.c
+++ b/sfcgal/lwgeom_sfcgal.c
@@ -18,19 +18,85 @@
- * Copyright 2012-2013 Oslandia <infos at oslandia.com>
+ * Copyright 2012-2020 Oslandia <infos at oslandia.com>
 #include "postgres.h"
 #include "fmgr.h"
 #include "utils/builtins.h"
-#include "../liblwgeom/liblwgeom.h"
 #include "lwgeom_pg.h"
 #include "lwgeom_sfcgal.h"
 #include "../postgis_config.h"
+#include "utils/elog.h"
+#include "utils/guc.h"
+#include "libpq/pqsignal.h"
+#include "../liblwgeom/liblwgeom.h"
+ * This is required for builds against pgsql
+PG_MODULE_MAGIC;
+#ifdef WIN32
+static void interruptCallback() {
+  if (UNBLOCKED_SIGNAL_QUEUE())
+    pgwin32_dispatch_queued_signals();
+#endif
+static pqsigfunc coreIntHandler = 0;
+static void handleInterrupt(int sig);
+ * Module load callback
+void _PG_init(void);
+void
+_PG_init(void)
+  coreIntHandler = pqsignal(SIGINT, handleInterrupt);
+#ifdef WIN32
+  GEOS_interruptRegisterCallback(interruptCallback);
+  lwgeom_register_interrupt_callback(interruptCallback);
+#endif
+    /* install PostgreSQL handlers */
+    pg_install_lwgeom_handlers();
+ * Module unload callback
+void _PG_fini(void);
+void
+_PG_fini(void)
+  elog(NOTICE, "Goodbye from PostGIS SFCGAL %s", POSTGIS_VERSION);
+  pqsignal(SIGINT, coreIntHandler);
+static void
+handleInterrupt(int sig)
+  /* NOTE: printf here would be dangerous, see
+   * https://trac.osgeo.org/postgis/ticket/3644
+   * TODO: block interrupts during execution, to fix the problem
+  /* printf("Interrupt requested\n"); fflush(stdout); */
+  /* request interruption of liblwgeom as well */
+  lwgeom_request_interrupt();
+  if ( coreIntHandler ) {
+    (*coreIntHandler)(sig);
 Datum postgis_sfcgal_version(PG_FUNCTION_ARGS);
 Datum sfcgal_from_ewkt(PG_FUNCTION_ARGS);
diff --git a/postgis/lwgeom_sfcgal.h b/sfcgal/lwgeom_sfcgal.h
similarity index 100%
rename from postgis/lwgeom_sfcgal.h
rename to sfcgal/lwgeom_sfcgal.h
diff --git a/postgis/sfcgal.sql.in b/sfcgal/sfcgal.sql.in
similarity index 99%
rename from postgis/sfcgal.sql.in
rename to sfcgal/sfcgal.sql.in
index ecc1cc8..5d8a629 100644
--- a/postgis/sfcgal.sql.in
+++ b/sfcgal/sfcgal.sql.in
@@ -12,7 +12,7 @@
 -- New SFCGAL functions (meaning prototype not already provided by GEOS)
-#include "sqldefines.h"
+#include "../postgis/sqldefines.h"
 -- INSTALL VERSION: POSTGIS_LIB_VERSION
diff --git a/sfcgal/sfcgal_after_upgrade.sql.in b/sfcgal/sfcgal_after_upgrade.sql.in
index 0000000..3e780e5
--- /dev/null
+++ b/sfcgal/sfcgal_after_upgrade.sql.in
@@ -0,0 +1,18 @@
+-- PostGIS - Spatial Types for PostgreSQL
+-- http://postgis.net
+-- Copyright (C) 2020 Regina Obe <lr at pcorp.us>
+-- This is free software; you can redistribute and/or modify it under
+-- the terms of the GNU General Public Licence. See the COPYING file.
+-- These are reserved for functions that are changed to use default args
+-- This is installed after the new functions are installed
+-- We don't have any of these yet for sfcgal
+-- The reason we put these after install is
+-- you can't drop a function that is used by sql functions
+-- without forcing a drop on those as well which may cause issues with user functions.
+-- This allows us to CREATE OR REPLACE those in general sfcgal.sql.in
+-- without dropping them.
diff --git a/sfcgal/sfcgal_before_upgrade.sql.in b/sfcgal/sfcgal_before_upgrade.sql.in
index 0000000..5d1e7f6
--- /dev/null
+++ b/sfcgal/sfcgal_before_upgrade.sql.in
@@ -0,0 +1,13 @@
+-- These are functions that need to be dropped beforehand
+-- where the argument names may have changed  --
+-- so have to be dropped before upgrade can happen --
+-- argument names changed --
Summary of changes:
 .gitignore                                         |   3 +
 GNUmakefile.in                                     |   2 +-
 NEWS                                               |   3 +-
 configure.ac                                       |   1 +
 extensions/postgis_sfcgal/Makefile.in              |   4 +-
 postgis/Makefile.in                                |  25 +--
 postgis/postgis_legacy.c                           |  24 ++-
 regress/Makefile.in                                |   7 +-
 sfcgal/Makefile.in                                 | 169 +++++++++++++++++++++
 {postgis => sfcgal}/lwgeom_sfcgal.c                |  74 ++++++++-
 {postgis => sfcgal}/lwgeom_sfcgal.h                |   0
 {postgis => sfcgal}/sfcgal.sql.in                  |   2 +-
 .../sfcgal_after_upgrade.sql.in                    |   8 +-
 .../sfcgal_before_upgrade.sql.in                   |  17 +--
 14 files changed, 289 insertions(+), 50 deletions(-)
 create mode 100644 sfcgal/Makefile.in
 rename {postgis => sfcgal}/lwgeom_sfcgal.c (91%)
 rename {postgis => sfcgal}/lwgeom_sfcgal.h (100%)
 rename {postgis => sfcgal}/sfcgal.sql.in (99%)
 copy topology/topology_drop_after.sql.in => sfcgal/sfcgal_after_upgrade.sql.in (69%)
 copy extensions/postgis_tiger_geocoder/sql_bits/add_search_path.sql.in => sfcgal/sfcgal_before_upgrade.sql.in (50%)
hooks/post-receive
