[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0alpha2-78-gd575a6e
Mon Oct 5 09:34:15 PDT 2020
the project "PostGIS".
       via  d575a6e738ef567b05d80096f41c383e264bd8dc (commit)
      from  678f526670b6b1805495431e62f12072bb9485cf (commit)
revisions in full, below.
commit d575a6e738ef567b05d80096f41c383e264bd8dc
Author: Raúl Marín <git at rmr.ninja>
Date:   Mon Oct 5 18:33:22 2020 +0200
    Adapt image generator to the changes in the library
    References #4672
diff --git a/doc/html/image_src/generator.c b/doc/html/image_src/generator.c
index 43cd0fc..b9eb574 100644
--- a/doc/html/image_src/generator.c
+++ b/doc/html/image_src/generator.c
@@ -78,8 +78,8 @@ pointarrayToString(char *output, POINTARRAY *pa)
 		POINT2D pt;
 		getPoint2d_p(pa, i, &pt);
-		lwprint_double(pt.x, 10, x, OUT_DOUBLE_BUFFER_SIZE);
-		lwprint_double(pt.y, 10, y, OUT_DOUBLE_BUFFER_SIZE);
+		lwprint_double(pt.x, 10, x);
+		lwprint_double(pt.y, 10, y);
 		if ( i ) ptr += sprintf(ptr, " ");
 		ptr += sprintf(ptr, "%s,%s", x, y);
@@ -111,9 +111,9 @@ drawPoint(char *output, LWPOINT *lwp, LAYERSTYLE *styles)
 	LWDEBUGF(4, "%s", "drawPoint called");
 	LWDEBUGF( 4, "point = %s", lwgeom_to_ewkt((LWGEOM*)lwp) );
-	lwprint_double(p.x, 10, x, OUT_DOUBLE_BUFFER_SIZE);
-	lwprint_double(p.y, 10, y1, OUT_DOUBLE_BUFFER_SIZE);
-	lwprint_double(p.y + styles->pointSize, 10, y2, OUT_DOUBLE_BUFFER_SIZE);
+	lwprint_double(p.x, 10, x);
+	lwprint_double(p.y, 10, y1);
+	lwprint_double(p.y + styles->pointSize, 10, y2);
 	ptr += sprintf(ptr, "-fill %s -strokewidth 0 ", styles->pointColor);
 	ptr += sprintf(ptr, "-draw \"circle %s,%s %s,%s", x, y1, x, y2);
Summary of changes:
 doc/html/image_src/generator.c | 10 +++++-----
 1 file changed, 5 insertions(+), 5 deletions(-)
hooks/post-receive
