[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0alpha2-79-g520af0e
Mon Oct 5 12:51:06 PDT 2020
the project "PostGIS".
       via  520af0e8d1bb6e9544d974713bb87e428ff4230b (commit)
      from  d575a6e738ef567b05d80096f41c383e264bd8dc (commit)
revisions in full, below.
commit 520af0e8d1bb6e9544d974713bb87e428ff4230b
Author: Sandro Santilli <strk at kbt.io>
Date:   Thu Feb 27 09:42:05 2020 +0100
    Work around PG13 drop of `FROM unpackaged` syntax
    - Always install empty extension--unpackage.sql scripts
    - Have run_test.pl use create/update trick for PG13
    - Re-enable check_all_upgrades.sh testing of unpackaged
    - Have postgis_extensions_upgrade use the unpackaged trick
    Fixes #4643
diff --git a/extensions/postgis/Makefile.in b/extensions/postgis/Makefile.in
index ef7a451..91b3fd8 100644
--- a/extensions/postgis/Makefile.in
+++ b/extensions/postgis/Makefile.in
@@ -32,6 +32,7 @@ PREREL_PREFIX = $(shell echo $(EXTVERSION) | \
 DATA_built = \
 	$(EXTENSION).control \
 	sql/$(EXTENSION)--$(EXTVERSION).sql \
+	sql/$(EXTENSION)--unpackaged.sql \
 	sql/$(EXTENSION)--unpackaged--$(EXTVERSION).sql \
 	$(NULL)
@@ -102,6 +103,9 @@ sql/$(EXTENSION)--unpackaged--$(EXTVERSION).sql: $(EXTENSION_UNPACKAGED_UPGRADE_
 		| $(PERL) ../../utils/create_unpackaged.pl postgis \
+sql/$(EXTENSION)--unpackaged.sql: Makefile | sql
+	echo "-- Nothing to do here" > $@
 sql:
 	mkdir -p $@
diff --git a/extensions/postgis_raster/Makefile.in b/extensions/postgis_raster/Makefile.in
index 856c956..cf9f182 100644
--- a/extensions/postgis_raster/Makefile.in
+++ b/extensions/postgis_raster/Makefile.in
 DATA_built = \
 	$(NULL)
@@ -74,6 +75,9 @@ sql/$(EXTENSION)--$(EXTVERSION).sql: $(EXTENSION_SCRIPTS) | sql
 	printf '\\echo Use "CREATE EXTENSION $(EXTENSION)" to load this file. \\quit\n' > $@
 	cat $^ >> $@
 sql/$(EXTENSION)--unpackaged--$(EXTVERSION).sql: $(EXTENSION_UNPACKAGED_UPGRADE_SCRIPTS) ../../utils/create_unpackaged.pl sql/$(EXTENSION)--ANY--$(EXTVERSION).sql Makefile | sql
 	# Ensure version is correct
 	cat sql/$(EXTENSION)--ANY--$(EXTVERSION).sql > $@
diff --git a/extensions/postgis_sfcgal/Makefile.in b/extensions/postgis_sfcgal/Makefile.in
index dd7ca48..b3c0019 100644
--- a/extensions/postgis_sfcgal/Makefile.in
+++ b/extensions/postgis_sfcgal/Makefile.in
@@ -25,6 +25,7 @@ PREREL_PREFIX = $(shell echo $(EXTVERSION) | \
 DATA_built = \
 	$(NULL)
@@ -73,6 +74,9 @@ sql_bits/sfcgal_comments.sql: ../../doc/sfcgal_comments.sql
 	mkdir -p sql_bits
 	cp $< $@
 #grep all lines that start with CREATE OR REPLACE FUNCTION, TRIGGER...
 #then replace CREATE OR REPLACE .. with ALTER EXTENSION..;
 #then remove default values and extra junk
diff --git a/extensions/postgis_topology/Makefile.in b/extensions/postgis_topology/Makefile.in
index 38e5128..63e88f4 100644
--- a/extensions/postgis_topology/Makefile.in
+++ b/extensions/postgis_topology/Makefile.in
@@ -34,6 +34,7 @@ PREREL_PREFIX = $(shell echo $(EXTVERSION) | \
 DATA_built = \
 	$(NULL)
@@ -78,6 +79,9 @@ sql_bits/topology.sql: ../../topology/topology.sql
 sql_bits/topology_comments.sql: ../../doc/topology_comments.sql
 	cp $< $@
 sql/$(EXTENSION)--unpackaged--$(EXTVERSION).sql: ../../topology/topology.sql ../../utils/create_unpackaged.pl sql/topology_upgrade.sql Makefile | sql
 	# Ugprade before packaging
 	cat sql/topology_upgrade.sql > $@
diff --git a/postgis/postgis.sql.in b/postgis/postgis.sql.in
index 9b19f05..e7ea8a5 100644
--- a/postgis/postgis.sql.in
+++ b/postgis/postgis.sql.in
@@ -2927,12 +2927,22 @@ BEGIN
 							JOIN pg_catalog.pg_namespace n ON (c.relnamespace = n.oid )
 							WHERE n.nspname = 'tiger' AND c.relname = 'geocode_settings') )
 			THEN
-				--force install in same schema as postgis only if postgis extension is installed
-				IF rec.name NOT IN('postgis', 'postgis_topology', 'postgis_tiger_geocoder') AND EXISTS (SELECT 1 FROM pg_catalog.pg_extension WHERE extname = 'postgis') THEN
-					sql = 'CREATE EXTENSION ' || rec.name || ' FROM unpackaged SCHEMA '
-					|| quote_ident( (SELECT ns.nspname FROM pg_catalog.pg_extension AS e INNER JOIN pg_catalog.pg_namespace AS ns ON e.extnamespace = ns.oid WHERE extname = 'postgis')) || ';';
+				-- Force install in same schema as postgis
+				SELECT INTO var_schema n.nspname
+				  FROM pg_namespace n, pg_proc p
+				  WHERE p.proname = 'postgis_full_version'
+				    AND n.oid = p.pronamespace
+				  LIMIT 1;
+				IF rec.name NOT IN('postgis_topology', 'postgis_tiger_geocoder')
+					sql := format(
+					          'CREATE EXTENSION %1$I SCHEMA %2$I VERSION unpackaged;'
+					          'ALTER EXTENSION %1%I UPDATE TO %3$I',
+					          rec.name, install_schema, rec.default_version);
 				ELSE
-					sql = 'CREATE EXTENSION ' || rec.name || ' FROM unpackaged;';
+					sql := format(
+					         'CREATE EXTENSION %1$I VERSION unpackaged;'
+					         'ALTER EXTENSION %1%I UPDATE TO %2$I',
+					         rec.name, rec.default_version);
 				END IF;
 				RAISE NOTICE 'Packaging extension %', rec.name;
 				RAISE DEBUG '%', sql;
diff --git a/regress/run_test.pl b/regress/run_test.pl
index 2fb74e3..7e4751e 100755
--- a/regress/run_test.pl
+++ b/regress/run_test.pl
@@ -431,6 +431,7 @@ my $geosver =  sql("select postgis_geos_version()");
 my $projver = sql("select postgis_proj_version()");
 my $libbuilddate = sql("select postgis_lib_build_date()");
 my $pgsqlver = sql("select version()");
+my $pgsqlvernum = sql("select current_setting('server_version_num')");
 my $gdalver = sql("select postgis_gdal_version()") if $OPT_WITH_RASTER;
 my $sfcgalver = sql("select postgis_sfcgal_version()") if $OPT_WITH_SFCGAL;
 my $scriptver = sql("select postgis_scripts_installed()");
@@ -1525,6 +1526,20 @@ sub prepare_spatial
 	return 1;
+sub package_extension_sql
+	my ($extname, $extver) = @_;
+	my $sql;
+	if ( $pgsqlvernum lt 130000 ) {
+		$sql = "CREATE EXTENSION ${extname} VERSION '${extver}' FROM unpackaged;";
+	} else {
+		$sql = "CREATE EXTENSION ${extname} VERSION unpackaged;";
+		$sql .= "ALTER EXTENSION ${extname} UPDATE TO '${extver}'";
+	return $sql;
 # Upgrade an existing database (soft upgrade)
 sub upgrade_spatial
@@ -1629,7 +1644,7 @@ sub upgrade_spatial_extensions
     elsif ( $OPT_UPGRADE_FROM =~ /^unpackaged/ )
-      $sql = "CREATE EXTENSION postgis VERSION '${nextver}' FROM unpackaged";
+			$sql = package_extension_sql('postgis', ${nextver});
     else
@@ -1642,7 +1657,7 @@ sub upgrade_spatial_extensions
     #print "CMD: " . $cmd . "\n";
     my $rv = system($cmd);
     if ( $rv ) {
-      fail "Error encountered altering EXTENSION POSTGIS", $REGRESS_LOG;
+      fail "Error encountered updating EXTENSION POSTGIS", $REGRESS_LOG;
       die;
@@ -1655,7 +1670,7 @@ sub upgrade_spatial_extensions
         # upgrade of postgis must have unpackaged raster, so
         # we create it again here
-        my $sql = "CREATE EXTENSION postgis_raster VERSION '${nextver}' FROM unpackaged";
+				my $sql = package_extension_sql('postgis_raster', ${nextver});
         print "Upgrading PostGIS Raster in '${DB}' using: ${sql}\n" ;
@@ -1672,7 +1687,8 @@ sub upgrade_spatial_extensions
         # left unpackaged
         print "Packaging PostGIS Raster in '${DB}' for later drop using: ${sql}\n" ;
-        $sql = "CREATE EXTENSION postgis_raster VERSION '${nextver}' FROM unpackaged";
+				$sql = package_extension_sql('postgis_raster', ${nextver});
         $cmd = "psql $psql_opts -c \"" . $sql . "\" $DB >> $REGRESS_LOG 2>&1";
         $rv = system($cmd);
         if ( $rv ) {
@@ -1703,7 +1719,7 @@ sub upgrade_spatial_extensions
         my $sql = "ALTER EXTENSION postgis_raster UPDATE TO '${nextver}'";
         if ( $OPT_UPGRADE_FROM =~ /^unpackaged/ ) {
@@ -1711,7 +1727,7 @@ sub upgrade_spatial_extensions
         my $cmd = "psql $psql_opts -c \"" . $sql . "\" $DB >> $REGRESS_LOG 2>&1";
         if ( $rv ) {
-          fail "Error encountered altering EXTENSION POSTGIS_RASTER", $REGRESS_LOG;
+          fail "Error encountered updating EXTENSION POSTGIS_RASTER", $REGRESS_LOG;
           die;
@@ -1721,7 +1737,7 @@ sub upgrade_spatial_extensions
       my $sql = "ALTER EXTENSION postgis_topology UPDATE TO '${nextver}'";
-				$sql = "CREATE EXTENSION postgis_topology VERSION '${nextver}' FROM unpackaged";
+				$sql = package_extension_sql('postgis_topology', ${nextver});
       print "Upgrading PostGIS Topology in '${DB}' using: ${sql}\n";
@@ -1729,7 +1745,7 @@ sub upgrade_spatial_extensions
       if ( $rv ) {
-        fail "Error encountered altering EXTENSION POSTGIS_TOPOLOGY", $REGRESS_LOG;
+        fail "Error encountered updating EXTENSION POSTGIS_TOPOLOGY", $REGRESS_LOG;
         die;
@@ -1739,7 +1755,7 @@ sub upgrade_spatial_extensions
 			my $sql;
-				$sql = "CREATE EXTENSION postgis_sfcgal VERSION '${nextver}' FROM unpackaged";
+				$sql = package_extension_sql('postgis_sfcgal', ${nextver});
 			elsif ( $OPT_UPGRADE_FROM && semver_lessthan($OPT_UPGRADE_FROM, "2.2.0") )
diff --git a/utils/check_all_upgrades.sh b/utils/check_all_upgrades.sh
index f5fc9bb..80b9231 100755
--- a/utils/check_all_upgrades.sh
+++ b/utils/check_all_upgrades.sh
@@ -115,31 +115,23 @@ for EXT in ${INSTALLED_EXTENSIONS}; do
   done
   # Check unpackaged->extension upgrades
-  # NOTE: unsupported since PostgreSQL 13
-  #       See https://trac.osgeo.org/postgis/ticket/4643
-  export PGDATABASE=template1
-  pg_version_num=`psql -XAtc "SELECT current_setting('server_version_num')"` || exit 1
-  if test "$pg_version_num" -lt 130000; then
-    for majmin in `'ls' -d ${CTBDIR}/postgis-* | sed 's/.*postgis-//'`; do
-      UPGRADE_PATH="unpackaged${majmin}--${to_version_param}"
-      # only consider versions older than ${to_version_param}
-      cmp=`semver_compare "${majmin}" "${to_version_param}"`
-      if test $cmp -ge 0; then
-        echo "SKIP: upgrade $UPGRADE_PATH ($to_version_param is not newer than $majmin)"
-        continue
-      fi
-      echo "Testing ${EXT} upgrade $UPGRADE_PATH"
-      export RUNTESTFLAGS="-v --extension --upgrade-path=${UPGRADE_PATH}"
-      make -C ${REGDIR} check && {
-        echo "PASS: upgrade $UPGRADE_PATH"
-        echo "FAIL: upgrade $UPGRADE_PATH"
-        failed
-    done
-  fi
+  for majmin in `'ls' -d ${CTBDIR}/postgis-* | sed 's/.*postgis-//'`; do
+    UPGRADE_PATH="unpackaged${majmin}--${to_version_param}"
+    # only consider versions older than ${to_version_param}
+    cmp=`semver_compare "${majmin}" "${to_version_param}"`
+    if test $cmp -ge 0; then
+      echo "SKIP: upgrade $UPGRADE_PATH ($to_version_param is not newer than $majmin)"
+      continue
+    fi
+    echo "Testing ${EXT} upgrade $UPGRADE_PATH"
+    export RUNTESTFLAGS="-v --extension --upgrade-path=${UPGRADE_PATH}"
+    make -C ${REGDIR} check && {
+      echo "PASS: upgrade $UPGRADE_PATH"
+      echo "FAIL: upgrade $UPGRADE_PATH"
+      failed
+  done
 done
Summary of changes:
 extensions/postgis/Makefile.in          |  4 ++++
 extensions/postgis_raster/Makefile.in   |  4 ++++
 extensions/postgis_sfcgal/Makefile.in   |  4 ++++
 extensions/postgis_topology/Makefile.in |  4 ++++
 postgis/postgis.sql.in                  | 20 ++++++++++++----
 regress/run_test.pl                     | 34 +++++++++++++++++++-------
 utils/check_all_upgrades.sh             | 42 +++++++++++++--------------------
 7 files changed, 73 insertions(+), 39 deletions(-)
hooks/post-receive
