[postgis-tickets] [PostGIS] #4681: Have ST_GetFaceGeometry print a WARNING if face edges are found but no polygon can be built
trac at osgeo.org
Tue Oct 6 13:08:04 PDT 2020
Reporter: strk | Owner: strk
Type: enhancement | Status: closed
Priority: medium | Milestone:
Component: topology | Version: master
Resolution: fixed | Keywords:
Comment (by laopsahl):
Ok I see, but with the Topology layer name it would be easier debug when
working eith many different topology layers on the same database.
[root at vroom4 ~]# grep Corrupted /var/log/postgres/*|sort -u
/var/log/postgres/postgresql-Sun.log:NOTICE: Corrupted topology: face
7995848 has no associated edges.
7995885 has no associated edges.
7995937 has no associated edges.
7995994 has no associated edges.
7996024 has no associated edges.
7996137 has no associated edges.
7996138 has no associated edges.
7996141 has no associated edges.
7996244 has no associated edges.
7996458 has no associated edges.
7996465 has no associated edges.
7996477 has no associated edges.
7996478 has no associated edges.
7996498 has no associated edges.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4681#comment:5>
